Topic: [Feature Request] Close the playback device on pause (Read 1355 times) previous topic - next topic
  • GrayShade
I'm not sure if this is related to foobar2000 or the output plugins, but..
can a option to close the playback device be added to the application settings? I would find something it useful together with the WASAPI output plugin, for example, which uses the exclusive mode. Otherwise, if I need to listen to something else for a few seconds I have to remember the track position.
  • fohrums
Otherwise, if I need to listen to something else for a few seconds....
This is very important. WASAPI works better in MusicBee because when I actually stop the audio I am now no longer in exclusive mode so I can listen to other medias.
So implementing this with Foobar will be such a big improvement! In fact I dont use WASAPI just becuase of this hassle. It's sad to say but i'm on Optical in/out in DirectSound output.
  • marc2003
  • Developer
file>preferences>playback>resume playback after restarting foobar2000.
now you can close foobar and it will remember the previous position when you start it again.
  • GrayShade
That's not a great workaround .
  • marc2003
  • Developer
fairy nuff.
  • ojdo
Get foo_playlist_attributes and activate "Bookmark last playback position" under
Preferences > Tools > Playlist attributes > Playback settings.
Now the playback position is remembered when stopping (not pausing) playback.
  • Peter
  • Administrator
Request noted.
