Topic: Foobar v1.2.x doesn't restart to play after long "Pause" (Read 824 times) previous topic - next topic
  • AndreaT
Hello Folks,
I have to report that, surely from Version 1.2.1 and still present in Ver 1.2.3 Beta2, my Foobar2000 doesn't restart to play after a long "Pause" (about 1 hour or more).
I am running it on a Windows 7 32bit OS with 4 GB RAM, all the MS SP/patches installed, and having ASIO as my standard output.
The ASIO driver I am using is the last version provided by MOTU (my DAC is the MOTU 896 mk3 hybrid).
The problem is easy to replicate, at least on my system: start to play something, pause it for at least 1 hour, then un-pause it: foobar should starve in tempt to restart the play.
To have foobar working again I have to close it and restart.
Kind regards,
Andrea
  • db1989
  • Global Moderator
Moved from 3rd Party Plugins. Have you tested whether pausing other applications using the same output method also causes freezing?
  • AndreaT
Hello db1989, sorry for having posted in the wrong thread, I was believing to be under the Suppport...
Regarding your question, I didn't tested other application because I am using only foobar.
Thanks to your suggestion, I will instal a demo version of JRiver and I will test it soon.
Regards, Andrea
  • db1989
  • Global Moderator
Thanks, as that may help determine whether the problem is in fb2k itself or in the drivers.
