Topic: Can I set up fb2k so a click/double-click in window will pause/resume? (Read 2339 times) previous topic - next topic
  • HeyThere
Hey guys, just a quick question.  I'm a new user of Foobar2000 and am missing one feature.  Is there a way to configure part of the player application so that a mouse click (or double-click) would pause/resume playing?  I'm not talking about the pause/play button but maybe on the album art area or the visualizations area - the same way this works on the MediaPlayer Classic (not MS) or PotPlayer?
Any helop is greatly appreciated.
Thank you.
  • HeyThere
Or another example would be AIMP player - where you can Middle-Click on either the "Visualization" or "Album Art" area of the player in order to play/pause.
Anyone know of an option like this for foobar2000?
  • dhromed
Nope, but you can of course bind spacebar to play/pause.
  • marc2003
you could replace your default artwork panel with WSH panel mod and install a script i made called artreader. it's inside this bundle here: http://db.tt/BInQ3Abm
by default the double click action locates the image in explorer but you can edit the script to change this behaviour. on line 44, you'll find this....
function on_mouse_lbtn_dblclk(x, y) {
    a.lbtn_dblclk(x, y);
replace it with
    fb.PlayOrPause();
  • HeyThere
replace it with
    fb.PlayOrPause();
Thank you very much for this - I got it set up and it works great!  One question...
Is there a simple code change to make this work using a single- Left-Click or a Middle-Mouse-Click?
  • marc2003
rename the function to on_mouse_lbtn_up or on_mouse_mbtn_up. i'm sure you can figure out what is what.
  • HeyThere
Thanks again - works well.  Before asking, I tried renaming it to on_mouse_lbtn_clk but it didn't work
Have a great day.
  • backbone10
sorry for hijacking this, but i am searching a similiar funcunality, which i was not able to configure by myself...
Can I set up fb2k so a click/double-click in window will send a track to playlist and a middle click will ADD to another (specific) playlist e.g. called "PREPARED"..
The idea behind is that i can go through the lib and listen all songs by leftclick and with middle click i can prepare them for burning....
i dont want to use the queue for that....
thx in advance
bb10
  • marc2003
you could look at file>preferences>media library>album list. you can bind the middle click to send to a new playlist - not a specific one though.....
i find the easiest way to send tracks to specific playlists is to have playlist tabs active (or a playlist manager panel) and simply drag/drop tracks from your library viewer onto them.
  • backbone10
hi marc2003,
thx for your answer. the first part was known to me but does not perform what i wanted
the second idea looks pretty good as an alternative, but i to make life easy i would need easy 2 separate playlists in Foobar side-by-side. i am searching for that, but this looks not possible, too...
maybe someone can help me with that ??
br
bb10
  • ruebe
if you want two playlist-viewers side by side, that show different playlists, you have to use esplaylist
this viewer gives you the possibility to lock every panel to a different playlist - in contrast to the standard behavior of the stock playlist viewer which only shows the selected playlist
  • Last Edit: 06 February, 2013, 07:45:06 AM by ruebe
