Topic: Stream from Google Music (Read 8200 times) previous topic - next topic
  • Lusitano
I would like to know if there's any way to stream my music from Google Music using foobar2000, by using a plugin or other method?
I found this http://foobar2000-google-music.googlecode.com/svn/trunk/ but don't know how to make it work.
  • dzid_
Maybe somehow using this DLNA server http://www.universalmediaserver.com/forum/...p?f=6&t=224
I was able to use the DLNA server to successfully stream from google music. I couldn't get seeking to work though
  • continous
You generally can't seek streaming media without server to client communication. In order to have that you would probably need to research into their mobile app.
  • Nixdagibts
What exactly do I have to download from this URL?
And how do I make it work with fb2k? Can someone gibe me some instructions please?
  • Andreasvb
First, a little heads-up. This was just a quick estimation over the code I saw. Unless you're a programmer or know how to code in HTML/PHP, this might be a bit complicated.
You'll need to use a web server with PHP support and place the files there. It will be in Chinese, so you may want to translate it.
Maybe also change to google.com/music/ instead of google.cn/music/ as well.
The path to foobar2000 seems to be hardcoded to d:\foobar2000\ so you'll need to change that too.
Latest update was in 2010, not sure if something has changed on Google's side, so it may not work, at all.
  • Last Edit: 28 July, 2013, 09:52:42 AM by Andreasvb
  • Nixdagibts
Thank you Andreasvb for the explanations
