Topic: morituri 0.2.0 "ears" released (Read 2483 times) previous topic - next topic
  • thomasvs
morituri is a CD ripper aiming for accuracy over speed.
Its features are modeled to compare with Exact Audio Copy on Windows.
This is morituri 0.2.0 "ears".
This is intended as a release for daring and curious people who've had enough
of the fact that Windows has a more accurate CD ripper than Linux.
Coverage in 0.2.0: 67 %  (1890 / 2807), 95 python tests
Features added in 0.2.0:
- added plugins system for logger
- added rip cd rip --logger to specify logger
- added reading speed, cdparanoia and cdrdao version to logger
- added rip drive analyze to detect whether we can defeat audio cache behaviour
- store drive offsets and cache defeating in config file
- rip drive list shows configured offset and audio cache defeating
- added rip image retag --release-id to specify the release id to tag with
- added %r/%R for release type to use in track/disc template
- added %x for extension to release template
Bugs fixed in 0.2.0:
-  89: Fails to rip track with \ in its name
- 105: Backslash in track names causes "Cannot find file" during rip
- 108: Unable to find offset / rip
- 109: KeyError when running "rip offset find"
- 111: Python traceback when config has no read offset for CD
-  76: morituri should allow for a configuration file
-  96: rip image retag: allow specification of release ID
- 107: Backslash in track name confuses AR step
- 112: add MusicBrainz lookup URL to generated logfile
morituri 0.2.0 is brought to you by:
Loïc Minier
Ross Burton
Christophe Fergeau
Thomas Vander Stichele
mustbenice
  • Nessuno
Macte virtute! But, could you please explain the reason (there must be one!) for such a ugly name to everyone who knows a little Latin?
Maybe you mean: "CDs are going to die soon"?
... I live by long distance.
  • piscvau
Hello
I am new to UNIX . I have been using extensively EAC on my WIndows PC. I have installed morituri but I do not understand the commands syntax.
I have found the offset.
I would like to convert each track to a flac file. And I would like to check with accuarte rip
I typed the following command rip cd --device /dev/cdrom rip --offset (myoffset). Is seems to work but it does not seem to check with accurate rip and I do not know where to find the flac files.
If anyon could help it sould be very helpful.
Piscvau
