Topic: A secret "known by signal processing experts" or nonsense? (Read 12054 times) previous topic - next topic
Actually, I did a bit of research on that topic, for the purpose of decorrelating channels to help stereo acoustic echo cancellation. What I found was that you can make phase shift inaudible even when channels aren't matched and while varying the amount of phase shift. What's important is only matching the channels below about 2 kHz, where the ear is sensitive to interaural phase difference (IPD).
Interesting, you've done more types of testing than I have. Also, when I said "the phase shift is changing" I should have been clearer. The type of phase shift effects I've tested vary the center frequency of the phase shift, not the amount of shift at a fixed frequency. So by "changing" I mean sweeping the frequency. Though I imagine changing the amount of shift at a fixed frequency would also be audible at midrange frequencies.
--Ethan
I believe in Truth, Justice, and the Scientific Method
  • Woodinville
http://www.wickeddigital.com.au/index.php/...eally-necessary
Sets out what is described as a White Paper by Marco Manunta of M2Tech. It contains the following passage (my emphasis)
"But there is something more. It’s known by signal processing experts, and absolutely not popularized amongst music lovers, that converting an analog signal into a discrete-time one (as it happens when converting from analog to digital) destroys the phase information in the two top octaves of the resulting spectrum. In a CD-standard digital recording, all phase information are lost from 5.5kHz up to 22kHz,"
Can any signal processing experts comment on whether this is true or not, and if so why. As a mere layman I am not able to understand why it even might seem be true.
It is false. It is utterly false, absurd, and insane. Your cell phone, MP3 player, and cable modem could not work, for instance, if there was any truth to this utterly preposterious foolishness.
J. D. (jj) Johnston
  • Woodinville
Above some frequency in what we call midrange, the ears lose their ability to discern phase.
Allow me to be more specific.
The ability to discern signal phase starts to degrade around 500Hz, and is almost completely gone by 2kHz, and completely gone by 4kHz.
HOWEVER, the ability to discern time delays in a non-stationary signal envelope at 15kHz is very good. So, time cues matter above 2kHz. A lot.
J. D. (jj) Johnston
  • Woodinville
--Ethan
So, try delaying a 10kHz gaussian impulse with a 4khz bandwidth by half a sample in one channel. Tell me you don't hear that in headphones, eh?
J. D. (jj) Johnston
  • jmvalin
  • Developer
Actually, I was changing what you call the "center frequency" as well. If you remove the part of my filter that was designed to leave the lower frequencies alone, you have a "comb allpass" filter:
A(z) = (a + z^-N)/(1 - a*z^-N)
I was actually changing not only a, but also the order N to avoid the "nulls" in the phase change.
Reply #30
If only I understood what that meant, or how to delay something by half a sample!
I agree that left-right phase differences are audible. I haven't tested this enough to be more specific, but I'm glad you and others have.
--Ethan
  • greynol
  • Global Moderator
Delay by a half sample: up-convert to a higher samplerate, perform the delay and then down-convert.
Pretty simple!
  • jmvalin
  • Developer
--Ethan
Actually, I've no idea what a "10kHz gaussian impulse with a 4khz bandwidth" would be, but delaying something by half a sample (or any fractional number of samples) is very easy to do, e.g. using a sinc filter. One thing I should have been more precise about in my earlier comment... you can get away with modifying the phase as long as it's above ~2 kHz and as long as the group delay (derivative of the phase response wrt frequency) is small enough. But as I said, as long as you're careful with how you do it, it's amazing how much you can get away with when playing with the phase. The real difficulty when the phase is involved is really how messing it up can cause other artefacts. e.g. changes in the actual power spectrum.
  • Woodinville
Reply #33
Pretty simple!
Even easier, it's a gaussian impulse, it has no energy outside Fs/2 to speak of, so you can shift it analytically.
it's of the form
e^(((t-t0)^2))/c)*sin(2*pi*f*(t-t0))
So you just change t0.
  • Last Edit: 17 January, 2013, 05:00:45 AM by CiTay
J. D. (jj) Johnston
Reply #34
Oh, you math guys...
Though I do understand up-sample, delay, down-sample.
--Ethan
