Topic: Connecting Speakers to my TV (Read 2655 times) previous topic - next topic
  • verdict
Good day everyone,
I apologize if this is the wrong forum, but this seemed to be the most appropriate one.
I own a Philips 32PFL5306H TV, I couldn't find an English website for it, but the Dutch website is http://www.philips.nl/c/televisie/5000-ser...=specifications
The details don't matter; what (I think?) is most important is that it has a Coaxial output for audio. Now I want to hook this TV up to my old speakers. I do not know what the name of the connections they have is, but they are those type of speakers you connect to an amplifier with 2 wires, that go into a red and a black connector. Well, that all works out and I can hook them up to the (old!) amplifier I still have just fine. (I can't test if they work, but you do hear them 'go on' when you turn on the power). However, connecting this amplifier to the TV has been problematic. What I have done is I have taken one of those cables which consist of 'a red wire and a white wire' on both sides (http://www.icidu.com/media/productdownloads/A-707307/images/A-707307%20Audio%20Cable%202x%20RCA%20M%202x%20RCA%20M%205m%20L.jpg) and I tried to connect this to the TV. The TV does have these inputs, but I soon learned that this is for a home cinema system, and it is input, not output. So now my question is, is there a way to connect this amplifier, which takes these red and white cables as input, to the TV, which only has coaxial output. And if not, what kind of amplifier would I have to buy, that I could still connect those speakers to (with the red and the black connectors)
I apologize for the long post, I hope it isn't too vague.
Kind regards
  • Apesbrain
Something like this would work:
http://www.amazon.com/FiiO-Digital-Analog-...nverter+FiiO+D3
This one says it includes a power adapter which you'll probably need (can't tell if included above):
http://www.amazon.com/D3-Digital-Converter.../ref=pd_cp_MI_0
You'll also need a short coaxial cable.
  • Last Edit: 30 December, 2012, 08:14:16 PM by Apesbrain
  • mzil
^That SPDIF coaxial digital output on the TV will provide Dolby Digital 5.1 at times and that FiiO D to A converter is expecting PCM stereo only.
http://www.p4c.philips.com/cgi-bin/dcbint/...n=32PFL5306H/12
The TV has a headphone out jack. A simple cord, no electronics or power adapters needed, can convert from its 3.5 mm stereo out to the RCA phono connection the amplifier takes. This also will allow the TV's remote control to vary the volume up and down at will.
http://www.amazon.com/s/ref=pd_sl_2msg7i2o...ini+plug+to+rca
  • adamjk
  • verdict
Thanks for all the replies, they are very useful indeed.
That does indeed sound like a solid option! The only thing I am wondering about is how big the loss in quality is using this method. Does the amplifier still influence the sound? I am going to use simple stereo speakers, so not having a 5.1 signal or anything is just fine.
  • Apesbrain
There is nothing inherently "low quality" about the headphone jack option and it has the convenience advantages mzil mentioned.  Try it and see what you think; an appropriate patch cord is not expensive.  If you still want to try the digital out, P17 of the manual indicates it can be configured to convert non-PCM (Dolby) to PCM stereo.
http://www.amazon.com/Dynex-Mini-Stereo-Au...ds=1%2F8+to+rca
  • mzil
99% of the sound quality you experience is dictated by what speakers you use, their placement and positioning in the room, and your room's acoustics. The method I described should work well no matter what amplifier you use.
