Topic: I cannot manage file associations/have icons with anything past 1.1.18 (Read 1228 times) previous topic - next topic
I have to keep going to back to Foobar 1.1.18 because the newer versions always ask me to allow Shell Updater.exe to make changes. This window never popped up on 1.1.18
Now, I cannot manage file associations with anything newer than 1.1.18. Also, with the newer versions I cannot get Foobar icons with any of my media files...is this something with my configuration??
This has been bugging me because I would like to update to the newest version.
I am running Windows 7 Home Premium 64 Bit
Thanks in advance
  • BenB
I've had that happen to me as well when installing foobar from a standard account on my comp. I solved it by installing foobar while using an administrator account.
  • Case
  • Developer (Donating)
It sounds like you disallow the program to make the required changes. If you allowed it to write the required settings to registry you would get your file association possibility back.
If I install it in safe mode, it worked...weird
  • db1989
  • Global Moderator
It would help, and possibly dispel any perceived weirdness, if you would answer Case’s implied question about whether or not you were answering yes – as you should – when asked whether or not you want to allow the requested changes.
  • Last Edit: 30 December, 2012, 10:52:23 PM by db1989
I did allow it to make changes
