Topic: UPnP MediaRenderer output | discussion (Read 129492 times) previous topic - next topic
Re: UPnP MediaRenderer output | discussion
Reply #300
The DLNA device I use is Marantz NR1608.
I'm sorry to ask something very basic, but if I can't find my device, what should I do ?
On the other hand, I can use the "cast ot device" function of Windows Media Player
 and confirmed using this component to other device.
Reply #301
Did you already try in foobar 2000:  click on: view > UNpN controler > select device ? Is it not there? If its there you can after that see it in preferences > output and select it there also.
Reply #302
The plugin still can't find my HEOS device (Marantz ND8006). Other software recognize it. There isn't anything related to that device in the foobar2000 console. Could it be possible Peter to add support for HEOS devices?
Can I use track metadata in stream-title config?
Reply #303
I've tried today the component with a SMSL DP3 and when starting the playback i have this error "Unrecoverable playback error: UPnP device error: XML error"
I've tried everything all day without finding any solution, does that mean that my streamer is incompatible with the component ?
My goal is just to use Foobar on a PC and render the music with the streamer.
Regards
Reply #304
Version 1.3 stable has been posted on the website.
Anyone having trouble with detection of their device, please update and try again.
When reporting issues or asking for help with a specific device, please include which version of this component you're using (as 1.3 greatly improves compatibility). If your device is detected but playback fails, please enable verbose console logging and post a console log of what happens during attempted playback.
Reply #305
Version 1.3 and verbose logging.
Still no love for Marantz ND8006. It isn't even listed in the devices. There's no log output considering that device.
Reply #306
(stuff...)
The attached xml as .txt should get you going with Denon/Marantz.  For some reason you are ignoring D&M announcements.  Maybe you are expecting to find MediaRenderer:1 top-most.  Same not-found with my Samsung but who cares about that.  You can get others to plug in the uris in this xml.txt if you need specific service/device xmls.
Reply #307
I own a Stream Magic V2 from Cambridge Audio and it does not play anything from Foobar200 via UPnP (WASAPI and the rest works).
Wavs, Flacs, MP3s, with DSD:UPnP or UPnP set as the device, the only effect is the "foobar200 audio stream" in the display.
By the way Mediamonkey plays to the device via UPnP. Attached are two logs and the device details.
Reply #308
Thanks for all the feedback.
A new update addressing all documented problems will be released early next week.
Reply #309
I've tried with the v1.3 now and i stil have the xml error and now a systematic foobar crash, i've tried with a portable foobar without any component verbose console loaded, it's similar.
I've also a xml error when trying with foobar Mac version.
Streamer : SMSL DP3
Reply #310
Peter, i don't know if the Foobar crash log is enough for you, i just don't know how to obtain the UPnP specific log.
Reply #311
Here is the device XML for Marantz ND8006.
Reply #312
I have Denon DNP-800NE network audio player
I use ver. 1.3 foo_out_upnp plugin but it is not recognize my denon :-(
I'm attaching xml of my denon
please help he. thanks
Reply #313
Please, someone can tell me how and in which directory I can retrieve the xml file ?
Reply #314
Ok, finally got the Verbose console log
Reply #315
Good day! Connected to foobar 2000 dynaudio connect via the UPnP MediaRenderer Output plug-in. Everything worked fine. Now for some reason, foobar 2000 does not see my device, re-reinstalling the component does nothing. Tell me, please, what to do?
I apologize for bad english, I write from a translator.
Reply #316
New version posted.
Devices that were not seen by the previous version - including above mentioned Denon and Marantz devices - should be now functional; thanks for the detailed reports.
Known crash bugs have been addressed.
Re SMSL DP3:
Please make a new console log from foo_out_upnp 1.3.1 and post it, it will log more details about what failed.
Reply #317
Thanks Peter, here is the new log with no Foobar crash.
Reply #318
Thanks a lot, this is exactly the info I wanted. I'll get back to you with a new beta version soon.
Reply #319
The 1.3.1 seems to be working flawlessly with my Marantz ND8006, thank you Peter!
A feature request: metadata (%artist%, %track% etc.) as stream title
Reply #321
Re stream titles-
It's been requested before, I really wish I could do it but there doesn't seem to be a way - without breaking gapless playback at least.
Reply #322
Thanks Peter, no more XML error, the playback still don't start.
the console is displaying this loop :
 [UPnP] Transport state: TRANSITIONING
[UPnP] Returned time: 00:00:00
Reply #323
Thanks Peter,
Denon DNP800NE works very well with 1.3.1
FYI: denon plays flac stream and it,s look like support pause too
Re stream titles : I'm vary sad...
thanks again
Reply #324
Thank you so much !!!
This new version works perfectly, my Denon Heos Link is in the list and is correctly addressed.
Great, great work !
