Topic: UPnP MediaRenderer output | discussion (Read 112818 times) previous topic - next topic
Re: UPnP MediaRenderer output | discussion
Reply #225
This is awesome!  I had to set my ancient tx-nr-609 to NET - DLNA other wise it said transport locked, but it works fine after doing that.  Thanks so much!
Reply #226
What it can be?
Opening track for playback: "song.mp3"
[UPnP] Device protocol info:
[UPnP] http-get:*:audio/mp3:*,http-get:*:audio/x-mp3:*,http-get:*:audio/mpeg:*,http-get:*:audio/mpeg3:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/wma:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:audio/ogg:*,http-get:*:audio/x-ogg:*,http-get:*:application/octet-stream:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/musepack:*,http-get:*:audio/x-musepack:*,http-get:*:audio/wavpack:*,http-get:*:audio/x-wavpack:*,http-get:*:audio/ape:*,http-get:*:audio/x-ape:*,http-get:*:audio/mp4:*,http-get:*:audio/m4a:*,http-get:*:audio/x-alac:*,http-get:*:audio/3gpp:*,http-get:*:audio/aiff:*,http-get:*:audio/x-aiff:*,http-get:*:audio/aif:*,http-get:*:audio/x-aif:*,http-get:*:audio/x-caf:*,http-get:*:audio/dsf:*,http-get:*:audio/dff:*,http-get:*:audio/basic:*
[UPnP] Listening on: 192.168.88.10:58591
[UPnP] Stream address: http://192.168.88.10:52550/4/stream.wav
[UPnP] HTTP request #4: HTTP/1.1 GET /4/stream.wav
[UPnP] HTTP concurrency: 1
[UPnP] Source: 192.168.88.14:35293
[UPnP] Accept: */*
[UPnP] Host: 192.168.88.10:52550
[UPnP] Serving WAV
[UPnP] Accept-Ranges: none
[UPnP] Connection: close
[UPnP] Content-Type: audio/wav
[UPnP] Server: Windows, UPnP/1.0 DLNADOC/1.50, foobar2000/1.x
[UPnP] TransferMode.dlna.org: Streaming
[UPnP] transport op: Play
[UPnP] transport op "Play" fail: user abort after 0:00.004894
Unrecoverable playback error: UPnP device error: XML error
[UPnP] Detached transport op failure: XML error
[UPnP] HTTP request #4 finished
[UPnP] HTTP concurrency: 0
Reply #227
Just what I needed, mostly works with KEF LS50W.  However two issues:
1) After the transition 'Pause->Play' I get white noise (!);  Stop, Next, or Previous are required before next successful Play. I get an intermittent "Unrecoverable playback error: UPnP device error: Action Failed". Spotify app driving the speakers does not have this issue.
Any thing you can do?
2) When there are two sources (say Foobar and Spotify) and one target (Speakers), playing each source preempts the other - which is great. On preempt, Spotify pauses its playlist but Foobar ends its playlist and on Play gives a message "Unrecoverable playback error: UPnP device error: Transition not available".
Enhancement request: the action on transition due to another source would be Pause (like Spotify app).
[Windows 10, Foobar 1.4 , foo_outupnp 1.0 ]     Foobar 1.3 had same white noise issue.
Reply #228
I just downloaded the new version 1.0, as I read that it is no longer beta.
But the pause-funcionality while streaming to my Yamaha RX-V3067 still doesn't work. Microsoft MediaPlayer is able to pause without any problems.
Furthermore neither title- and album-information can be displayed at the Yammi nor a cover-picture is shown at the connected TV. Using Microsoft MediaPlayer shows all these informations.
Is there any chance to successfully wait for the implementation of these desired features? I gave the information about this buggy behaviour already more than one year ago...
Yours
André
Reply #229
Hello Peter,
first, thank you very much for sharing your work with us!
I am wondering if it is possible to use your plugin to stream DSD audio to DLNA renderers, such as Sony STR-DN1080 - which are capable of receiving native DSD streams?
Thanks,
Andrej
reverse stereo channels
Reply #230
just by accident I found out, that stereo channels are reverse when I play via UPnP MediaRenderer Output 1.0. I did several dedicated tests with special audio files, containing channel checks (Accuphase Special Sound Selection Track 18), installed UPnP/DLNA Renderer, Server, Control Point 0.99.49, did the same tests and also used other UPnP renderer. Beyond doupt: UPnP MediaRenderer Output 1.0 has reverse channels.
Please could somebody else check this?
Martin
Re: reverse stereo channels
Reply #231
I just checked it by playing dedicated L- and R-signals one after the other via UPnP MediaRenderer Output 1.0 using my Yamaha RX-V3067. But my signals are definitely not reversed.
How did you check it? Using an external Player? Perhaps the analog CD<=>Amp-Connection  a n d  speaker-cables are reversed, so you don't get the reverse-channel-effect using the player in contrast to the use of the UPnP MediaRenderer Output 1.0?
André
Reply #232
I use A Bricasti M1 DAC as external player. It has a network-input as well as USB and other digital inputs. And I can definitely exclude, that the reverse channels are caused by hardware!
Why? When I install the older plugin "UPnP/DLNA Renderer, Server, Control Point 0.99.49" and play via network, channels are ok. When I play via USB, channels are ok. When I use PlugPlayer on my android-tablet and stream from my NAS or my SSD, channels are ok.
But when I use "UPnP MediaRenderer Output 1.0" (Device>UPnP : M1 or DSD : UPnP : M1), channels are reverse.
This is a matter of fact!
Martin
Reply #233
Hi, first time on this forum. Long-time fb2k user just getting to grips with UPnP rendering. And many thanks to Peter for this plug-in.
I can confirm the stereo channel reversing issue with UPnP MediaRenderer Output 1.0. Using fb2k 1.41 on Windows 2008R2, my external music renderer is a SoTM SMS-200 Ultra connected to USB DAC built into my pre-processor.
To check, I have tried the following:
  • Logitech Media Server 7.92 to SotM renderer on same Windows server - OK
  • fb2k over HDMI using Windows 7 - OK
  • Playing direct on SoTM via a USB stick (i.e. by-passing the Windows servers) - OK
In all examples the audio chain downstream of the SoTM was identical. Pre-processor to power amp to speakers. And I used 2 identical music files to test this - a 44.1/16 and 88.2/24 flac stereo file.
Reply #234
Hello,
my first post here on this thread and forum as well.
My configuration is:
W10Pro with fb2k 1.4.1 with foo_out_upnp 1.0
I can confirm that it works flawlessly with Primare PRE32 wit MM30 card and also with old Denon AVR-4311, but my problem is that it not recognize Marantz AV8805 with Heos.
Question is - is it possible to add support for this Marantz av processor?
thank you in advance for answer
Do you know why isn't possibile
Reply #235
Ref reversed channels, my workaround (for now) is to use the reverse channels option in DSP.
In case it helps, I attach the console output as well as the description.xml from from the SoTM SMS-200.
192.168.1.187 is the SoTM renderer
192.168.1.11 is the Windows host
Reply #236
Hi rag987,
thanks for confirming that UPnP MediaRenderer Output 1.0 has reverse stereo channels! I hope, Peter will read our discussion and go into this bug.
Martin
Reply #238
with volumio and raspberry - works only with 16 bit output, 24 bit=horrible noise
what is the cause of the problem?
Reply #239
New beta version [1.2 beta 1]:
https://www.foobar2000.org/temp/UPnP_MediaRenderer_Output-1.2b1.fb2k-component
The major change is that by default live-encoded FLAC is now used to send our audio to the device. This seems to cause fewer bugs than WAV or LPCM which we used before, at least with the devices I tested. You can still override the preferred format via advanced preferences, and see what is actually used in console. Actual used format depends on what the device claims to support.
Other than that, LPCM mode with bit depth other than 16 bits has been disabled by default (new toggle in advanced preferences added), as it was causing all kinds of bugs with renders, crashing the heck out of Kodi, etc. Which probably not matter, FLAC being the new default.
Reply #240
Peter
This version works well for me. I tried with the new flac format
My player is a DENON DRA 100
Is there any chance now to have dynamic stream title iplemented ?
Didier
Reply #241
It is not possible to deliver changing track titles using UPnP without interrupting playback / introducing gaps between tracks, which I will not do.
Reply #242
Thanks for the reply
Reply #243
Any chance you can have this also work with OpenHome renderers?
