Topic: UPnP MediaRenderer output | discussion (Read 248301 times) previous topic - next topic
Re: UPnP MediaRenderer output | discussion
Reply #500
The setup is exactly what you described.  When I try to use volume control I get the following error.  Also, I have musical spectrum visualization placed in a columui panel and it is not operational on the source computer.
Scalar volume control not supported with this device.
Please use volume up / volume down menu commands or keyboard shortcuts.
Reply #501
It doesn't support Google Devices like Nest Mini, Nest Audio and Nest Hub?
How can these devices be seen in the plugin?
Reply #502
They're not DLNA/UPnP renderers.
Have you tried proxying them to DLNA renderers with BubbleUPnP Server?
Reply #503
I didn't know they are not DLNA/UPnP renderers... I asked because Mediamonkey 5 sees also these devices.
I'l check with the BubbleUPnP Server
Thank you for the reply
Reply #504
Using the BubbleUPnP server, the plugin sees Google's devices but after a few seconds the playback stops. When I press "PLAY" it plays for a few more seconds and then stops again. Do you know why?
The same problem occurs regardless if I configure Google devices either as DLNA or OpenHome renderers.
So, the only solution for steaming music to all my devices (Google's and Yamaha's) still remains Mediamonkey 5
I would prefer foobar.
Reply #505
I don't unfortunately. I've just proxied a Nest speaker to DLNA and it's currently playing 16/44 FLAC's fine.
I've performed that test on foobar 1.6.12, UPnP MediaRenderer 1.4, BubbleUPnP Server 0.9-update46.
Do you have any DSP's active? Might be worth trying from a fresh portable install with just the UPnP MediaRenderer installed.
I'm surprised it even lists the OpenHome proxy. You shouldn't enable both in BubbleUPnP Server just the DLNA proxy as the foobar plugin can't control an OpenHome device, and it can cause conflict.
Given you've got multiple speakers is there a reason why you want to control them from a Windows machine? Would a UPnP server and an Android/iOS app not be more flexible?
Reply #506
Thanks to the author of the plugin, all works well. My configuration:
Sony TV KD-55XF8505
Config:
# Specific Sony device fixes
manufacturer=Sony Corporation
model=MediaRenderer
preferred-format=LPCM
#reports-time=true
supports-FLAC=true
ps
foobar2000-x64_v2.1_preview_2023-05-30
Reply #507
I recently updated to Foobar2000 v2.0 (32 bits, with UPnP MediaRenderer Output v1.4) and it looks like playing 96 kHz audio over my Sonos Connect no longer works. AFAIK this was never a problem before.
I currently have a workaround in place in the form of a DSP resampler to 48k, but I wonder if this isn't a bug?
There's a small chance that I already had a resampler running (globally) in the previous version, but I'm not sure. In that case: sorry for bothering ;)
EDIT: It looks like Sonos does not support sample rates > 48 kHz, so it may indeed be the case that I had a global resampler running previously... (https://developer.sonos.com/build/content-service-add-features/supported-audio-formats/flac-best-practices/)
Reply #508
Hello everyone,
I tried to use UPnP Mediarender to stream multicanals music (5.1 DTS-CD files and 5.1 FLAC) to my Home Theatre Receiver (Denon AVR-X2600H). Unfortunately, when I do so, the music is "downmixed" to stereo.
Has anyone succeeded to stream multicanals musics using UPnP Mediarender or another Foobar plugin  ? Thanks!
Reply #509
Hello Everyone , first of all , I am French so as I am 67 yo my English is a little rusty.
Thank you Peter for this plugin , and I have a single question
Is it possible to output a multichannel (5.1) stream to a renderer
I see that Foobar output MCH when I send audio with HDMI directly to my Onkyo AVR and the Onkyo says PCM MCH
But when I send the same stream to My Orange TVBox which is connected with HDMI to the Onkyo the Onkyo says PCM 2.0
Thank You for answer and have a great day
Reply #510
In complement to my first post , this is the renderer I'd like to play PCM MCH
I do not know if it is able to do such thing
Friendly name : Décodeur TV UHD
IP address : 192.168.1.11
Manufacturer : SoftAtHome
Manufacturer URL : http://www.softathome.com
Model : SoftAtHome Media Renderer
Model number : 1.7.19
Model description : DLNA 1.5 Compliant Media Renderer from SoftAtHome
Model URL : http://www.softathome.com
Serial number : 83237547
Supported formats:
http-get:*:text/xml:DLNA.ORG_PN=DIDL_S
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_TN
http-get:*:audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get:*:image/jpeg:*
http-get:*:image/gif:*
http-get:*:image/png:*
http-get:*:audio/wav:*
http-get:*:audio/x-wav:*
http-get:*:audio/wave:*
http-get:*:audio/mp4:*
http-get:*:audio/x-mp4:*
http-get:*:audio/mpeg4:*
http-get:*:audio/x-mpeg4:*
http-get:*:audio/m4a:*
http-get:*:audio/x-m4a:*
http-get:*:audio/3gpp:*
http-get:*:audio/aac:*
http-get:*:audio/flac:*
http-get:*:audio/x-flac:*
http-get:*:audio/ogg:*
http-get:*:audio/vorbis:*
http-get:*:video/x-divx:*
http-get:*:video/x-matroska:*
http-get:*:video/x-msvideo:*
http-get:*:video/avi:*
http-get:*:video/msvideo:*
http-get:*:video/vnd.avi:*
http-get:*:audio/avi:*
http-get:*:audio/x-matroska:*
http-get:*:video/mp2t:*
http-get:*:video/vnd.dlna.mpeg-tts:*
http-get:*:video/mp1s:*
http-get:*:video/mp2p:*
http-get:*:video/mpeg:*
http-get:*:video/mpeg2:*
http-get:*:video/mpv:*
http-get:*:video/mp4:*
http-get:*:video/x-mp4:*
http-get:*:video/mov:*
http-get:*:video/quicktime:*
http-get:*:video/x-quicktime:*
http-get:*:text/m3u:*
http-get:*:audio/x-mpegurl:*
http-get:*:audio/x-scpls:*
http-get:*:application/vnd.ms-wpl:*
http-get:*:video/x-ms-asf:*
Reply #511
Hey this works great THANKS!!!...the only thing is the visualizations dont work. I guess this is a bug or fix needed???
Reply #512
Hi, I installed this today, but my files don't start playing (and as such also no sound coming from my amplifier.
I try to play a FLAC 16 bit /44,1. But as soon as I press Play it freezes. Though, I get no error in the console.
Anyone, any ideas what it could be?
This is the device report:
Friendly name : Versterker
IP address : 192.168.1.108
Presentation URL : http://192.168.1.108
Manufacturer : Lenbrook Industries
Manufacturer URL : https://nadelectronics.com/
Model : NAD Amplifier C338
Model number : 1.0
Model description : NADAmpDMR
Model URL : https://nadelectronics.com/product/c-338-classic-digital-dac-amplifier/
Serial number : 1234567890
Supported formats:
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:*:application/ogg:*
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get:*:audio/aiff:*
http-get:*:audio/x-aiff:*
EDIT: the audio does play if I cast with VLC to the amplifier, or if I cast my full laptop to the amplifier. Both things, for I guess obvious reasons, I don't want.
Reply #513
Can I use this component to stream audio files from my PC with Foobar2000 installed, to my android phone? (in the Foobar2000 android app would be ideal).
The following component used to be able to do it, but it isn't 64bit compatible:
https://www.foobar2000.org/components/view/foo_upnp
Reply #514
Hopefully this plugin could get some love, as it seems a number of devices are currently not working that appear to work okay with e.g. VLC.
I have a similar situation, in my case the streamer has the following details:
Friendly name : SOLO
IP address : 10.0.0.3
Presentation URL : http://10.0.0.3
Manufacturer : LibreWireless
Manufacturer URL : http://www.librewireless.com
Model : LibreWireless
Model number : 1.0
Model description : LibreSyncDMR
Model URL : http://www.librewireless.com/Mediarenderer
Supported formats:
Firewall rules are in place, when pressing play the console reports:
[UPnP] Opening device:
[UPnP] manufacturer=LibreWireless
[UPnP] model=LibreWireless
[UPnP] name=SOLO
[UPnP] Stream format: 16-bit 44100Hz 2ch
[UPnP] Device protocol info:
[UPnP] http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/wav:*,http-get:*:audio/x-wav:*,http-get:*:application/ogg:*,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO,http-get:*:audio/aiff:*,http-get:*:audio/x-aiff:*
[UPnP] Listening on: 10.0.0.13
[UPnP] Stream address: http://10.0.0.13:63096/1/stream.l16
[UPnP] HTTP request #1: HTTP/1.1 HEAD /1/stream.l16
[UPnP] HTTP concurrency: 1
[UPnP] Source: 10.0.0.3:56784
[UPnP] User-Agent: CyberGarage-HTTP/1.0
[UPnP] HOST: 10.0.0.13:63096
[UPnP] Accept: text/html,application/xhtml+xml,application/xml;q=0.9,audio/*;q=0.6
[UPnP] Serving LPCM
[UPnP] TransferMode.dlna.org: Streaming
[UPnP] Server: UPnP/1.0 DLNADOC/1.50, foobar2000/2.x
[UPnP] Content-Type: audio/L16;rate=44100;channels=2
[UPnP] Connection: close
[UPnP] Accept-Ranges: none
[UPnP] HTTP request #1 finished
[UPnP] HTTP concurrency: 0
[UPnP] transport op: Play
[UPnP] HTTP request #2: HTTP/1.1 GET /1/stream.l16
[UPnP] Source: 10.0.0.3:56786
[UPnP] User-Agent: stagefright/1.2 (Linux;Android
[UPnP] isTimeSeek: 0
[UPnP] Host: 10.0.0.13:63096
[UPnP] Connection: keep-alive
[UPnP] Accept-Encoding: gzip,deflate
[UPnP] Serving LPCM
[UPnP] transport op "Play" fail: Action Failed after 0:00.092049
[UPnP] == LAST REPLY XML ==
[UPnP] <?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
 <s:Body>
  <s:Fault>
   <faultcode>s:Client</faultcode>
   <faultstring>UPnPError</faultstring>
   <detail>
    <UPnPError xmlns="urn:schemas-upnp-org:control-1-0">
     <errorCode>501</errorCode>
     <errorDescription>Action Failed</errorDescription>
    </UPnPError>
   </detail>
  </s:Fault>
 </s:Body>
</s:Envelope>
[UPnP] == XML END ==
Unrecoverable playback error: Action Failed
[UPnP] HTTP request #2 finished
[UPnP] UPnP begin enum devices
[UPnP] UPnP device: SOLO :: http://10.0.0.3:38400/description.xml
[UPnP] UPnP end enum devices
Reply #515
Argon Solo does not support UPnP, but Chromecast is supported. Think you are using Chromecast when playing from VLC to Solo. You can play from Foobar2000 to Solo using BubbleUPnP server.
Reply #516
Thanks sacduser, i'm not sure what VLC uses, do you know how i can check that?
When i use BubbleUPnP itself (the player), the Argon Solo shows 2 interfaces: Chromecast and DLNA, i can use those interchangeably.
Another client that is able to stream to the Solo is MusicBee, that one doesn't support Chromecast but uses a UPnP/DLNA plugin:
https://getmusicbee.com/addons/plugins/11/upnp-dlna-device-support/
[edit]
This is how the Solo is reported in BubbleUPnP client:
Reply #517
 Hello All,
I stream my music from Foobar2000 (on a PC Window10) to my uPnP streamer Atoll ST300 (used in this case as a renderer device, private ethernet network).
No issue with the audio, but I never succeded to make the art album (or other metadata) displayed on my streamer screen during the playback, I get only the message "Foobar2000 audio stream"  displayed in the ST300.
Any idea to make the album art displayed in the renderer screen ?
Thanks for your support.
Acell
Reply #518
It's just a stream capture from foobar, so no metadata or album art. A UPnP server would solve both of those problems e.g. MinimServer.
Reply #519
Thanks SimBun for your answer
I face no issue when I stream by an App on my smartphone (Atoll's one or BubbleUPnP ) from my NAS or from Foobar2000 Audio server (or MinimServer).
My issue is when I want to use Foobar2000 on my PC, to take advantage of its huge potential for sorting my around 10 000 albums, that not allows Smartphone's App.
Acell
Reply #520
When using BubbleUPnP (or the Atoll app) to control playback, the controller sends the renderer (the Atoll) metadata about the resource it wants to play, which includes not only your tag metadata (album, artist e.t.c.) but also the URL of the track to play and any associated artwork. As the Atoll approaches the end of the current track it requests the next track from the controller and the cycle continues with new metadata being sent.
UPnP MediaRenderer doesn't send tracks, it sends foobar's output as a single audio stream (to the Atoll it's one very long track), so there's no way to provide updated metadata.
Whilst it's not as flexible as foobar MinimServer is very configurable. What is it you find lacking?
Reply #521
Thank you for your explanation.
I don't know very well Minimserver. I well know Audirvana and for example, about the tag "genre" is not managed by the same way.
I tag my albums with "genre",  including sub-genre as"Jazz" or "Jazz-Big Band" or "Jazz-Be-bop" ... Same for other music as Classical one.
1) With Foobar, I can sort all the albums by genre CONTAINING the word "Jazz" and NOT ONLY the single word "Jazz" => in Foobar (on PC, and after settings) , a sort by genre with the word "Jazz" will address all the albums with genre : "Jazz", "Jazz-Big Band", ... With Audirvana, I will get only albums with "Jazz" genre (not sub-genre). And it is the same with all Controller Apps on smartphone I know. Reason why I prefer using Foobar on PC.
2) With Foobar (on PC), once you get your albums sorted by genre, you can also set ac clear "sub-sorting" by artist, with clear display separation artist by artist.
.. And I can describe more advantages. But for sure I am developping my Foobar version for many years and it is not obvious.
In summary, Foobar2000 on PC is much more comfortable for managing a very large music collection (10,000 albums).
Reply #522
I play most of my music with fb2k and UPNP and really miss the visualization feedback. I remember reading somewhere that this is by design because of the unpredictable latency and response time of the different UPNP clients.
Is there room for discussion about adding a couple of parameters so that the advanced user can tweak his/her setup and still enjoy visualizations?
