Topic: TAudioConverter (Read 201018 times) previous topic - next topic
  • NappyHead
TAudioConverter
Reply #300
This is working great. Unless I'm doing something wrong, can I have the option to embed art work to files and also copy to output folder. Might sound a bit redundant, but just asking.
NH
  • bwaslo
TAudioConverter
Reply #301
ozok,
Below is the log (with the bitdepth set to 16).
BTW, tonight I tried converting the FLAC 5.1 to OGG.  It converted,  but on playback the channels seem to be scrambled ?(RIGHT Rear plays only bass).
I tried a conversion using Audacity and it got the channels correct.  Audacity also seems to do the convert to AC3 ok.  But I can't do Audacity in batch mode, so it would take forever to convert all my files!
Thanks, Bill
Log of attempted conversion from FLAC (a 5.1 file) to AC3.  Returns immediately on beginning the encode portion:
[3/28/2013 7:47:49 PM]  Started deleting temp files...
[3/28/2013 7:47:49 PM]  Temp Folder: C:\Users\Bill\AppData\Local\Temp\TAudioConverter\
[3/28/2013 7:47:49 PM]  Deleted 0 file(s).
[3/28/2013 7:47:49 PM] Finished deleting temp files.
[3/28/2013 7:48:47 PM]  Started deleting temp files...
[3/28/2013 7:48:47 PM]  Temp Folder: C:\Users\Bill\AppData\Local\Temp\TAudioConverter\
[3/28/2013 7:48:47 PM]  Deleted 1 file(s).
[3/28/2013 7:48:47 PM] Finished deleting temp files.
[3/28/2013 7:48:47 PM] Number of commands per process are as follows:
[3/28/2013 7:48:47 PM] Encoder1: 2
[3/28/2013 7:48:47 PM] Encoder2: 0
[3/28/2013 7:48:47 PM] Encoder3: 0
[3/28/2013 7:48:47 PM] Encoder4: 0
[3/28/2013 7:48:47 PM] Encoder5: 0
[3/28/2013 7:48:47 PM] Encoder6: 0
[3/28/2013 7:48:47 PM] Encoder7: 0
[3/28/2013 7:48:47 PM] Encoder8: 0
[3/28/2013 7:48:47 PM] --------------------------------------------
[3/28/2013 7:48:47 PM] Starting encoding process
[3/28/2013 7:48:47 PM] Command lines:
[3/28/2013 7:48:47 PM] ----Encoding Summary----
[3/28/2013 7:48:47 PM]        -Number of processes: 2
[3/28/2013 7:48:47 PM]        -Copy tags: False
[3/28/2013 7:48:47 PM]        -Enable artwork: False
[3/28/2013 7:48:47 PM]        -Copy artwork to output: True
[3/28/2013 7:48:47 PM]        -Copy external artwork: False
[3/28/2013 7:48:47 PM]        -Download lyric: False
[3/28/2013 7:48:47 PM]        -Add encoder suffix: True
[3/28/2013 7:48:47 PM]    +Audio
[3/28/2013 7:48:47 PM]        -Encoder: FFMpeg AC3
[3/28/2013 7:48:47 PM]        -Quality: 300
[3/28/2013 7:48:47 PM]        -Bit Depth: 16
[3/28/2013 7:48:47 PM]    +Effects
[3/28/2013 7:48:47 PM]        -Disabled
[3/28/2013 7:48:47 PM] Temp: C:\Users\Bill\AppData\Local\Temp\TAudioConverter\
[3/28/2013 7:48:47 PM] Output: D:\Music
[3/28/2013 7:49:02 PM] TAudioConverter could locate all the output files
[3/28/2013 7:49:02 PM] TAudioConverter converted files with speed x24 (Converted 00:05:35 in 00:00:14).
  • Last Edit: 28 March, 2013, 07:56:20 PM by bwaslo
  • ozok
TAudioConverter
Reply #302
@bwaslo can you send me EncoderLog1? It holds outputs of backends.
@NappyHead this was asked before by Daffy. I added that to my to-do list.
  • ozok
TAudioConverter
Reply #303
Again a link to TAC.exe and tools folder for you guys to try. I tried to add support for "Part/Position" tag which hopefully indicates to disc number. I also empty tags will not be replaced with "unkown", instead the will remain empty.
  • cyberdux
TAudioConverter
Reply #304
Once again, nice work ozok. Thank you
  • eahm
TAudioConverter
Reply #305
Thanks for the update.
[Disc %discnumber%] gives result [Disc ] (1 space) without the number of the disc. foobar2000 for example gives Disc 1. [Disc %discnumber% ] gives [Disc  ] (2 spaces) so the tag is not really recognized.
That tag string I was using was too old and needed to be revised. I changed it to: %artist%\[%date% - ]%album%\[Disc %discnumber%]\%tracknumber%. %title% and it should be ok for both programs once %discnumber% works.
As someone else already asked, I don't remember who, why you never added AIFF? ...and WMA Lossless since you added the Lossy one?
But hey, I don't use them, zero care for them here.
  • Last Edit: 29 March, 2013, 02:20:30 PM by greynol
  • Brazil2
TAudioConverter
Reply #306
Thanks but any chance for a portable version update as well ?
  • ozok
TAudioConverter
Reply #307
  • Brazil2
TAudioConverter
Reply #308
But notice that the custom temporary folder bug is still there.
  • ozok
TAudioConverter
Reply #309
Update:
-Added: Support for fdkaac (thx to o-l-a-v for binaries)
-Added: Support for .aiff and .aif files (thx to eahm)
-Added: Custom output folder structures (thx to NappyHead and eahm)
-Added: New textboxes, trackbars, etc (some settings are reseted)
-Added: New progress view layout
-Fixed: Summary didn't show if custom tags were used
-Fixed: Some texts couldn't be seen if skins were disabled
-Updated: AlphaControls full version 8.31 Beta  (thx for donations)
  • eahm
TAudioConverter
Reply #310
Thanks for the update, few things:
- I can't find AIFF from the codec list.
- Please use the much improved OpusEnc 1.1 alpha: http://www.hydrogenaudio.org/forums/index....st&p=823712 (we can easily overwrite it anyway if you rather not use beta/alpha).
- Are you using "-a 1" / "--afterburner 1" with fdk-aac (improved quality)? Enabled by default.
- qaac 2.18 is out.
- Please use flac.exe mod4 (by Case) with 2GB+ support (http://www.hydrogenaudio.org/forums/index....st&p=725304).
%discnumber% works perfectly! Thanks for this.
I think it's ready for mainstream now, I will start suggesting it to family and friends and it's already in my utilities folder.
  • Last Edit: 02 April, 2013, 03:50:23 PM by eahm
  • ozok
TAudioConverter
Reply #311
Aiff files are accepted as input. I'll add encoding to aiff later. I didn't want to include alpha version of an encoder but you can always replace it manually.
I thought it was set by default.
  • Last Edit: 02 April, 2013, 03:27:35 PM by ozok
  • Brazil2
TAudioConverter
Reply #312
Afterburner is enabled by default:
 -a, --afterburner <n>         Afterburner
                                 0: Off
                                 1: On(default)
  • eahm
TAudioConverter
Reply #313
Brazil, didn't notice that before. Thanks.
  • Last Edit: 02 April, 2013, 03:39:34 PM by eahm
  • Daffy
TAudioConverter
Reply #314
--0.8.3
"Always On Top" is still locking up the program on my machine.  Works for a while, but then it just freezes up completely after a few minutes.  This time it locked it up while trying to open the log after an encode.  Need to use the task manager to end the process to start it up again.  No problems when "Always On Top" is turned off.
  • o-l-a-v
TAudioConverter
Reply #315
0.8.3 is an good update. Except the encoder quality sliders i must say.
Take LAME for instance. Try to get the VBR quality at exactly 4. It's impossible! And there is no way to write 4 manually.
Ozok, please either remove the sliders and enable text input, or keep the sliders (unnecessary gui function in my opinion) and enable manual text input.
Some encoders also miss this slider (QAAC for instance), so this seems like a hasty added feature :S
+ FLAC to fdkaac removes all tags
+ Would be cleaner to have nero encoder inside the tools-folder. Make a folder inside tools named "nero". Inside you have a textfile named "place_neroenc_here.txt" for instance?
  • Last Edit: 03 April, 2013, 04:49:17 AM by o-l-a-v
  • Brazil2
TAudioConverter
Reply #316
I agree about text input
Meanwhile you can use arrow keys
Nope, it works for me
  • ozok
TAudioConverter
Reply #317
@Daffy I still can't reproduce that problem. I'll do more tests to reproduce it.
@o-l-a-v I'll make textboxes editable.
  • kokuyo
TAudioConverter
Reply #318
Thank you for corresponding to fdkaac.
  • eahm
TAudioConverter
Reply #319
%discnumber% wasn't recognized when I tested fdk-aac, I will go more testing later.
  • Daffy
TAudioConverter
Reply #320
Thanks for trying.  I have no idea why it's locking up on me.  I'm not a programmer.
Also, it crashed on me about a dozen times last night during some encodes.  I was getting some kind of error report screen popping up with all kinds of data tabs of code asking me if I wanted to send in a report.  Again, only way out was to shut down the program and restart it.  Never seen those before so I'm sorry to report this version is very buggy.
  • ozok
TAudioConverter
Reply #321
@eahm actually it's extraced from source so it should work with ever encoder. Are you certain that source has that information?
@Daffy if you get these error dialogs, then there must be a bugreport.txt next to TAudioConverter.exe. If you could send me it via email or PM it'd be great.
  • o-l-a-v
TAudioConverter
Reply #322
TAudioConverter is using FOREVER to make the final log files after successfull conversion of several files. Converted maybe 30 FLACS to MP3, creating logs took maybe 4 minutes alone.
  • ozok
TAudioConverter
Reply #323
"--verbose" command which made lame to output lots of data to console was passed. I replaced it with "--nohist" so now not only necessary info is written but also it is easier for TAC to parse Lame's progress.
Here is fixed exe for installer version: https://dl.dropbox.com/u/9617171/TAudioConverter.7z
  • NappyHead
TAudioConverter
Reply #324
Thanks for the updates, and it's almost perfect for me. Not sure anyone else has ran into this issue, but saving the temp files until the conversion process is completed is causing my hard drive to full up when converting a large number of files. Maybe change the option or give option to delete temp WAV file when the conversion  is complete per file. Maybe bypass the recycle bin and delete temp files permanently
Thanks again
NH
  • Last Edit: 05 April, 2013, 03:50:55 PM by NappyHead
