Error when trying to extract audio from a mpg movie:
Media info
Format : MPEG-PS
File size : 149 MiB
Duration : 14mn 57s
Overall bit rate : 1 395 Kbps
Writing library : encoded by TMPGEnc b12e
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Duration : 14mn 57s
Bit rate : 1 150 Kbps
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.454
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 122 MiB (82%)
Writing library : TMPGEnc b12e
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 14mn 57s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 24.0 MiB (16%)
Encoder 1
Encoder 1 Output:
ffmpeg version N-49610-gc2dd5a1 Copyright © 2000-2013 the FFmpeg developers
built on Feb 5 2013 13:20:59 with gcc 4.7.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth
--enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-libass
--enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm
--enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb
--enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger
--enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame
--enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx
--enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 52. 17.101 / 52. 17.101
libavcodec 54. 91.100 / 54. 91.100
libavformat 54. 61.104 / 54. 61.104
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 35.101 / 3. 35.101
libswscale 2. 2.100 / 2. 2.100
libswresample 0. 17.102 / 0. 17.102
libpostproc 52. 2.100 / 52. 2.100
[mpeg @ 003891a0] max_analyze_duration 5000000 reached at 5000000 microseconds
Input #0, mpeg, from 'G:\Film\Barnefilmer\Karius og Baktus (1954)\Karius og Baktus.1954.norsk tale.xvid.saga.mpg':
Duration: 00:14:56.97, start: 0.346711, bitrate: 1394 kb/s
Stream #0:0[0x1e0]: Video: mpeg1video, yuv420p, 352x288 [SAR 178:163 DAR 1958:1467], 1150 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
Stream #0:1[0x1c0]: Audio: mp2, 44100 Hz, stereo, s16p, 224 kb/s
Stream map '0:1010' matches no streams.
Edit: When muxing it to mkv it manages to extract create a file of 0 bytes.
