Topic: TAudioConverter (Read 203860 times) previous topic - next topic
  • eahm
TAudioConverter
Reply #275
Good job with the self-extracting portable exe and the name of the folder.
Thanks for the update.
  • Daffy
TAudioConverter
Reply #276
Re: Version 0.8.2.1226
  • When "Always On Top" is selected, after an encode the program locks up completely.  All buttons and ability to close/exit are frozen and it requires me to go into Task Manager to end the process to shut down.
  • The embed artwork to output file from artwork already embedded in source file is working fine.  Awesome.  However, per my initial request is there a way to do this AND copy/extract a duplicate image of the embedded artwork into the same output folder?  We now have the either/or option but not both.  In other words, copy all tags and artwork over from source file AND drop a folder.jpg image in the folder.  That would be ideal.
  • When skins are disabled white fonts show up in certain areas making it very difficult to see text.
I'll do so more testing and report back anything else I can find.  Thanks for the update!
  • Last Edit: 25 March, 2013, 01:35:15 AM by Daffy
  • ozok
TAudioConverter
Reply #277
@Daffy:
1) Unfortunately I couldn't reproduce that problem. I check "Always on top", start an encode and after it is done I can use controls on the window.
2) I couldn't make it available in this version but it will be there with next release.
3) I'll look into this.
To those having tag issues, unfortunately and dues to my carelessness all the samples sent to me earlier are lost. Please send me new ones if you can because I can't reproduce tag copying errors with the files I already have.
TAudioConverter
Reply #278
Good job!
How about a feature that, for example, convert CDImage.tak+CDImage.cue to CDImage.flac+CDImage.cue directly, and change the "file line" in *.cue to a new one?
  • ozok
TAudioConverter
Reply #279
@extremerock I'll see what I can do. I assume you want to do this in batch because you can do this easily by hand.
@To all, I'm planning to remove skinning support. It looks nice but it actually limits me and also creates way too much problems. What do you think about it?
  • eahm
TAudioConverter
Reply #280
I disable the skins every time I do some test.
BUT, you don't really see the words with the system default colors.
  • Last Edit: 25 March, 2013, 02:33:15 PM by eahm
  • ozok
TAudioConverter
Reply #281
@eahm don't worry they will be fixed too.
Now I come to think of it, thanks to donations I can afford to buy a licence of skinning component which means userface can be more united and I can get better support for it. Thanks for donations.
  • Last Edit: 25 March, 2013, 07:30:40 PM by ozok
  • Daffy
TAudioConverter
Reply #282
@Daffy:
Always on top is always locking up on me.  Now it's just happening randomly, not after a particular encode as previously reported.  Tried to open logs after an encode and it locked up.  Not sure what I can tell you other than it's not working (at least for me - Windows 7 64-bit).  When it's disabled the program works fine and I have yet to have it lock up on me.
  • Last Edit: 27 March, 2013, 03:52:06 AM by Daffy
  • o-l-a-v
TAudioConverter
Reply #283
Possibility to add custom "encoder" tag, where TAudioConverter just writes name of encoder, version and settings. For instance "QAAC v2.17 -tvbr 120"?
Would make it easier to figure out which encoder version, settings etc. is used in future.
  • ozok
TAudioConverter
Reply #284
@Daffy Can you try this TAudioConverter.exe: https://dl.dropbox.com/u/9617171/TAudioConverter.7z Just replace it with your exe but please make sure you have a backup your TAudioConverter.exe because this one isn't even beta. Also ignore the warning at the start.
@o-l-a-v added to to-do list.
  • wood11
TAudioConverter
Reply #285
How about the quality of converted audios ?
  • Last Edit: 27 March, 2013, 09:58:39 AM by db1989
  • NappyHead
TAudioConverter
Reply #286
Thanks for a great program. Is it possible to add the ability to set the output folder structure.
something like <Album Artist>\<Album>\<Number> - <Album Artist> - <Title>
NH
  • eahm
TAudioConverter
Reply #287
NH
This, 50 times. I always forgot to ask and it would be really useful. Personalized obviously.
  • Last Edit: 27 March, 2013, 02:47:34 PM by eahm
  • ozok
TAudioConverter
Reply #288
I don't understand your question. TAC uses well-known encoders as backend.
@eahm
@NappyHead
I'm working on it.
I finished adapting GUI for skinning component. I think especially progress window looks really cool. Here is a screenshot.
  • Last Edit: 27 March, 2013, 03:51:31 PM by ozok
  • ozok
TAudioConverter
Reply #289
Download this and copy it to TAudioConverter directory (copy TAudioConverter.exe and "Tools" folder). It is for setup version and make sure you have a backup before replacing. It offers a very crude support for what you guys asked.
Supported tags:
Title: %title%
Artist: %artist%
Album: %album%
Track No: %number%
Genre: %genre%
Date: %date%
I can add more tags need be.
  • Aldem
TAudioConverter
Reply #290
Hi !
First, thank you for the good work. I have a suggestion. If possible, I'd like TAC to be able to convert .AIF and .AIFF files to any other format.
Thanks, keep up the good work.
Alan
  • bwaslo
TAudioConverter
Reply #291
I've been trying to convert 5.1 channel FLAC files to something my WDTV box is able to play correctly (the box has a bug in that it scrambles the channels of 5.1 or 7.1 FLAC.... Western Digital seems to be in no rush to fix that..).  I can convert to WAV and that plays, but I'd like to save a little space (6 channel 24/96 files are huge).  I tried going to AAC, but WDTV doesn't do that either.  Tried AC3, but TAudioConverter just returns right after the FLAC decode stage and says it's done.... but the AC3 file is empty.
Am I doing something wrong?  Or is this a bug in TAudioConverter (or the FFMpeg tool it uses)?
(nice Delphi App, by the way.  I'm still programming in Delphi 5, should update to a newer version some day)
  • eahm
TAudioConverter
Reply #292
ozok, this is what I use with foobar2000:
%artist%/[%date% - ]%album%/[Disc %discnumber%]/%tracknumber%. %title%
Can you add %discnumber% and change Track No to %tracknumber% if it's not a problem?
edit:
Thanks for sorting the codecs alphabetically (TAK comes before TTA though and the AAC ones are not ordered  ).
I have almost no more reasons to not suggest TAC to friends and family.
  • Last Edit: 27 March, 2013, 11:26:22 PM by eahm
  • Daffy
TAudioConverter
Reply #293
When I replaced the *.exe file I get an error saying "Can't find fdkaac.exe. Please re-install."  I assume this is the warning you told me to ignore.  However the program doesn't start so I guess this test isn't working.  Sorry.
  • Last Edit: 28 March, 2013, 12:23:26 AM by Daffy
  • eahm
TAudioConverter
Reply #294
Did you replace the Tools folder too?
  • ozok
TAudioConverter
Reply #295
@Daffy the file in the link has been updated since I wrote that post. At the time I wrote this to you fdkaac wasn't added. Now as eahm said you must replace "tools" folder which includes fdkaac.exe.
@eahm I'll see what I can do.
@bwaslo, can you send me a log? Also setting bit depth to 16 might solve the problem. Unicode support that comes with D2009 has been a huge leap. I used to use Delphi 7.
@Aldem, added to to-do list.
  • Last Edit: 28 March, 2013, 03:50:36 AM by ozok
  • kokuyo
TAudioConverter
Reply #296
fdkaac setting options doesn't have the VBR mode.
Why?
  • Last Edit: 28 March, 2013, 06:43:11 AM by kokuyo
  • ozok
TAudioConverter
Reply #297
@eahm can you see disk number tag with mediainfo? If so, what is the name of the tag? Also please use "\" instead of "/" if you want to make folder. I re-ordered codec names so they are really alphabetically sorted now.
@kokuyo I added it now.
  • eahm
TAudioConverter
Reply #298
ozok, I've used mediainfo maybe twice, I do I see the tags?
edit:
It seems it's using the Vorbis tag "DISCNUMBER"? http://mediainfo.sourceforge.net/en/Support/Tags
  • Last Edit: 28 March, 2013, 12:15:56 PM by eahm
  • NappyHead
TAudioConverter
Reply #299
Supported tags:
Title: %title%
Artist: %artist%
Album: %album%
Track No: %number%
Genre: %genre%
Date: %date%
Thank you very much for the quick work, but I have one problem.
Use this for filename "%trackno% - %artist% - %title%" get this for file %trackno% - Betty Wright - Circle Of Heartbreak
Any clue
NH
My bad saw my mistake..
  • Last Edit: 28 March, 2013, 05:11:30 PM by NappyHead
