Topic: TAudioConverter (Read 206366 times) previous topic - next topic
  • ozok
TAudioConverter
Reply #200
I think what you say is a feature in Windows 7, not something i did.
  • javmaclean
TAudioConverter
Reply #201
It isn't possible to install your latest version (posted  at 14:43 on this forum). It immediately replies with the message:
  "Can't find fhgaacenc.exe. Please re-install"
I've managed to reproduce the bug in your latest official version (install: "TAC(0.7.7.1045)(setup).exe"), which deletes source files, even when it is not specified, which I don't appear to be able to do in TAC anyway.
I add a source directory (Add folder) and then try to do a downsizing of the bitrate of the audio files in the source directory, putting the results in a target directory.
There is an error, saying it can't find a set of files.
Afterwards the source files in the directory have all been deleted although this wasn't (and even can't be) selected. Bad news!
There is also no target directory created.
Here is a copy of the TAC log:
[10-Feb-2013 17:34:39] Started deleting temp files...
[10-Feb-2013 17:34:39] Temp Folder: C:\Users\javm\AppData\Local\Temp\TAudioConverter\
[10-Feb-2013 17:34:39] Deleted 9 file(s).
[10-Feb-2013 17:34:39] Finished deleting temp files.
[10-Feb-2013 17:34:40Number of commands per process are as follows:
[10-Feb-2013 17:34:40] Encoder1: 4
[10-Feb-2013 17:34:40] Encoder2: 4
[10-Feb-2013 17:34:40] Encoder3: 4
[10-Feb-2013 17:34:40] Encoder4: 4
[10-Feb-2013 17:34:40] Encoder5: 0
[10-Feb-2013 17:34:40] Encoder6: 0
[10-Feb-2013 17:34:40] Encoder7: 0
[10-Feb-2013 17:34:40] Encoder8: 0
[10-Feb-2013 17:34:40] Starting encoding process
[10-Feb-2013 17:34:40] Command lines:
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-1 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-1 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-1 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-1 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-5 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-5 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-5 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-5 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-2 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-2 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-2 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-2 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-6 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-6 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-6 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-6 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-3 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-3 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-3 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-3 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-7 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-7 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-7 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-7 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-4 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-4 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-4 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-4 of 8 - Kevin Anderson - Slan Hunter.mp3"
 -y -i "C:\JM\Audiobooks\AE Van Vogt (audio)\AE van Vogt & Kevin Anderson - Slan Hunter\SLHU-8 of 8 - Kevin Anderson - Slan Hunter.mp3" -threads 0 -vn  -f wav -map 0:0  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-8 of 8 - Kevin Anderson - Slan Hunter.wav"
 --cbr -b 24  --verbose  -q 1 --id3v2-only  "C:\Users\javm\AppData\Local\Temp\TAudioConverter\SLHU-8 of 8 - Kevin Anderson - Slan Hunter.wav" -o "C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-8 of 8 - Kevin Anderson - Slan Hunter.mp3"
----Encoding Summary----
       -Number of processes: 4
       -Copy tags: True
       -Extract artwork: True
   +Audio
       -Encoder: Lame
       -CBR: 24 kbps
       -Algorithm quality: 1
       -Bit Depth: Original
   +Effects
       -Disabled
Temp: C:\Users\javm\AppData\Local\Temp\TAudioConverter\
Output: C:\JM\Audiobooks\AAA Conversion  Output
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-1 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-2 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-3 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-4 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-5 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-6 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-7 of 8 - Kevin Anderson - Slan Hunter.mp3
[10-Feb-2013 17:34:41] Cannot find output file C:\JM\Audiobooks\AAA Conversion  Output\\SLHU-8 of 8 - Kevin Anderson - Slan Hunter.mp3
BTW it would be nice to have just the target folder structure stored and not all the tree above it.
An example:
The source files are in directory "source" under:
   C:\myfles\xx\yy\source
The target directory is:
   C:\target
Your current behaviour when specifying "Create folder structure in output" is to put the files in:
   C:\target\myfles\xx\yy\source
Why not just put them in:
   C:\target\source
This would be a lot cleaner.
  • Last Edit: 10 February, 2013, 01:24:10 PM by db1989
  • cyberdux
TAudioConverter
Reply #202
@cyberdux and @o-l-a-v try this exe. Please note that this is not portable version.
-I tried to add ArtistSort, AlbumSort, ComposerSort, AlbumArtistSort, NameSort to QAAC and ALAC. Although no error occurs while encoding, MediaInfo shows "soal" instead of "ALBUMSORT".
-Opus should show track info properly now.
-QAAC and ALAC will now have comment tags copied.
-I added more tag fields to musepack.
Where can I get a list of ape tag fields?
Thanks ozok. I am not being able to download from dropbox presently but I will try again later. (Managed with Google Chrome.)
I have "Can't find fhgaacenc.exe. Please re-install"
mp3Tag has a comprehensive list of fields for just about any file type in its help section and also mapping between file types
  • Last Edit: 10 February, 2013, 04:15:32 PM by cyberdux
  • o-l-a-v
TAudioConverter
Reply #203
Flac to MPC is almost good, but removes "Total Tracks". Still aborts if bit depth is 24 and I don't change it by setting.
Flac to Opus has same tag problem. All AAC-formats aswell
  • Last Edit: 10 February, 2013, 04:44:45 PM by o-l-a-v
  • ozok
TAudioConverter
Reply #204
You must replace your TAudioConverter.exe with this one. This is not a setup, just program exe. I should have made that clear.
@javmaclean sorry for the data lost. I hope you had a back-up. Please re-download link above. I updated it so that it has a log which records files deleted.
  • cyberdux
TAudioConverter
Reply #205
Sorry for my stupidity. I worked that out on my way to work - haha. I'll try again when I get home.
  • o-l-a-v
TAudioConverter
Reply #206
Ozok: At "audio effects", "Channels". Shouldn't 6ch be supported aswell?  Converting 6ch ac3 to aac (for instance) without edit audio effects creates a 6ch aac (Using QAAC), so it manages 6ch yep?
Edit: Just kidding, QAAC 6ch did not encode..
  • Last Edit: 11 February, 2013, 04:14:16 PM by o-l-a-v
  • botface
TAudioConverter
Reply #207
ozok,
      I've just given Taudioconverter another try. It's moved on a bit since I last tried it, which is nice to see. Just a couple of suggestions that would make it my 1st choice converter :
  • An option for Wavpack as an output format
  • An option to use the lossywav pre-processor with lossless output formats
Edit : One other thing I just noticed is that maybe the error reporting could be improved. 2 of my tracks didn't convert and it wasn't obvious from the log. Once I'd noticed and checked the log it still isn't obvious why they didn't convert
  • Last Edit: 12 February, 2013, 10:16:51 AM by botface
  • ozok
TAudioConverter
Reply #208
botface, did you look at Encoder1, Encoder2 ... logs? They are backends' output and can give you a better idea about the problem.
  • carpman
TAudioConverter
Reply #209
I agree with botface's requests. Didn't realise Wavpack had been omitted.
The reason I think lossyWAV would be so useful is that "normal" people aren't going to go through the hassle of setting up command lines (just not going to happen). I've recommended lossyWAV to non-techie types and they won't go near it. It would be cool to say just download TAudioConverter select LossyWAV and choose "standard" then choose FLAC, done (there's your lossyFLAC files).
C.
PC = TAK + LossyWAV  ::  Portable = Lame MP3
  • botface
TAudioConverter
Reply #210
I tried some more files. This time it created the output file structure but didn't produce any converted output files. I'm trying to convert to FHG AAC from a variety of source file types. Maybe I don't have something set up correctly (although fhgaac.enc is in the TAudioConverter directory)?
Here's the log :
[12/02/2013 19:35:13] Started deleting temp files...
[12/02/2013 19:35:13] Temp Folder: C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\
[12/02/2013 19:35:13] Deleted 1 file(s).
[12/02/2013 19:35:13] Finished deleting temp files.
[12/02/2013 19:35:13] Trying to detect bit depth: 01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).m4a [Depth is: ]
[12/02/2013 19:35:13] Trying to detect bit depth: 01 Waiting In The Wings.mp4 [Depth is: ]
[12/02/2013 19:35:13] Trying to detect bit depth: Various~Those_Dance_Band_Years~side1.wav [Depth is: 16]
[12/02/2013 19:35:13] Trying to detect bit depth: 01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.wv [Depth is: 16]
[12/02/2013 19:35:13] Trying to detect bit depth: John Stanley - Concerto for Strings Op2 No1.ogg [Depth is: ]
[12/02/2013 19:35:13Number of commands per process are as follows:
[12/02/2013 19:35:13] Encoder1: 9
[12/02/2013 19:35:13] Encoder2: 6
[12/02/2013 19:35:13] Encoder3: 0
[12/02/2013 19:35:13] Encoder4: 0
[12/02/2013 19:35:13] Encoder5: 0
[12/02/2013 19:35:13] Encoder6: 0
[12/02/2013 19:35:13] Encoder7: 0
[12/02/2013 19:35:13] Encoder8: 0
[12/02/2013 19:35:13] Starting encoding process
[12/02/2013 19:35:13] Command lines:
 -y -i "C:\Documents and Settings\User1\My Documents\101 Guitar Tips - Adam St-James\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).m4a" -threads 0 -vn  -f wav  "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).wav"
 --vbr 2 "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).wav" "C:\Documents and Settings\User1\My Documents\TAC\Documents and Settings\User1\My Documents\101 Guitar Tips - Adam St-James\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).m4a"
 "C:\Documents and Settings\User1\My Documents\TAC\Documents and Settings\User1\My Documents\101 Guitar Tips - Adam St-James\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).m4a" -meta:artist="Adam St-James" -meta:title="P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.)" -meta:genre="Data & Other" -meta:composer="Adam St-James" -meta:album="101 Guitar Tips" -meta:year="2006" -meta:comment="Ripped by Winamp"
 -y -i "F:\20's 78's on Vinyl (from Arthur)\Various~Those_Dance_Band_Years~side1.wav" -threads 0 -vn -acodec pcm_s16le -f wav  "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\Various~Those_Dance_Band_Years~side1.wav"
 --vbr 2 "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\Various~Those_Dance_Band_Years~side1.wav" "C:\Documents and Settings\User1\My Documents\TAC\20's 78's on Vinyl (from Arthur)\Various~Those_Dance_Band_Years~side1.m4a"
 "C:\Documents and Settings\User1\My Documents\TAC\20's 78's on Vinyl (from Arthur)\Various~Those_Dance_Band_Years~side1.m4a" -meta:artist="Unkown" -meta:title="Unkown" -meta:genre="Unkown" -meta:composer="Unkown" -meta:album="Unkown" -meta:year="0" -meta:comment="TAudioConverter"
 -y -i "F:\Audio Files\Classical\Baroque Odds & Ends\John Stanley - Concerto for Strings Op2 No1.ogg" -threads 0 -vn  -f wav  "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\John Stanley - Concerto for Strings Op2 No1.wav"
 --vbr 2 "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\John Stanley - Concerto for Strings Op2 No1.wav" "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Baroque Odds & Ends\John Stanley - Concerto for Strings Op2 No1.m4a"
 "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Baroque Odds & Ends\John Stanley - Concerto for Strings Op2 No1.m4a" -meta:artist="Collegium Musicum 90, Simon Standage" -meta:title="Concerto for Strings Op2 No1" -meta:genre="Baroque" -meta:composer="John Stanley" -meta:album="Concerto for Strings Op2 No1" -meta:year="0" -meta:comment="From Radio"
 -y -i "F:\Audio Files\Rock, Pop etc\BBM (Baker, Bruce And Moore)\Around The Next Dream\01 Waiting In The Wings.mp4" -threads 0 -vn  -f wav  "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 Waiting In The Wings.wav"
 --vbr 2 "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 Waiting In The Wings.wav" "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Rock, Pop etc\BBM (Baker, Bruce And Moore)\Around The Next Dream\01 Waiting In The Wings.m4a"
 "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Rock, Pop etc\BBM (Baker, Bruce And Moore)\Around The Next Dream\01 Waiting In The Wings.m4a" -meta:artist="BBM (Baker, Bruce And Moore)" -meta:title="Waiting In The Wings" -meta:genre="Rock" -meta:composer="Unkown" -meta:album="Around The Next Dream" -meta:year="1994" -meta:comment="TAudioConverter"
 -y -i "F:\Audio Files\Classical\Bach CPE\Bach CPE - Hamburg Sinfonias Nos. 1-6\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.wv" -threads 0 -vn -acodec pcm_s16le -f wav  "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.wav"
 --vbr 2 "C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.wav" "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Bach CPE\Bach CPE - Hamburg Sinfonias Nos. 1-6\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.m4a"
 "C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Bach CPE\Bach CPE - Hamburg Sinfonias Nos. 1-6\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.m4a" -meta:artist="Capella Istropolitana, Christian Benda" -meta:title="Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto" -meta:genre="Classical" -meta:composer="Bach CPE" -meta:album="C.P.E. Bach - Hamburg Sinfonias Nos. 1-6" -meta:year="1996" -meta:comment="Wq182"
       -Number of processes: 2
       -Copy tags: True
   +Audio
       -Encoder: FHG AAC
       -VBR: 2
   +Effects
       -Disabled
Temp: C:\Documents and Settings\User1\Local Settings\Temp\TAudioConverter\
Output: C:\Documents and Settings\User1\My Documents\TAC\
[12/02/2013 19:35:32] Cannot find output file C:\Documents and Settings\User1\My Documents\TAC\Documents and Settings\User1\My Documents\101 Guitar Tips - Adam St-James\01 - Adam St-James - P4 C Scales, 8 Modes (Starting With III, Then IV, Etc.).m4a
[12/02/2013 19:35:32] Cannot find output file C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Rock, Pop etc\BBM (Baker, Bruce And Moore)\Around The Next Dream\01 Waiting In The Wings.m4a
[12/02/2013 19:35:32] Cannot find output file C:\Documents and Settings\User1\My Documents\TAC\20's 78's on Vinyl (from Arthur)\Various~Those_Dance_Band_Years~side1.m4a
[12/02/2013 19:35:32] Cannot find output file C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Bach CPE\Bach CPE - Hamburg Sinfonias Nos. 1-6\01 Sinfonia in G major, Wq. 182 No. 1 - 1. Allegro di molto.m4a
[12/02/2013 19:35:32] Cannot find output file C:\Documents and Settings\User1\My Documents\TAC\Audio Files\Classical\Baroque Odds & Ends\John Stanley - Concerto for Strings Op2 No1.m4a
  • Last Edit: 12 February, 2013, 03:14:38 PM by db1989
  • ozok
TAudioConverter
Reply #211
botface, do you have winamp installed? Fhgaacenc.exe needs files that come with winamp.
  • botface
TAudioConverter
Reply #212
Yes, but it's an old version. However I thought I'd extracted the required files from the current versions as per the instructions that you gave for TAudioConverter (libsndfile-1.dll and fhgaacenc.exe IIRC). Should I have anything else in the TAC directory?
  • o-l-a-v
TAudioConverter
Reply #213
Ok, now i understand it.
The original ac3 file is 5.1. TAudio converter says it 6ch. I can't duplicate the error i got when encoding 5.1 ac3.
But in the effect settings, should not the "sampling rate" and "channels" be adjusted to what choosen codec supports? Like, QAAC does not support 6ch, but others do.
One more thing: Can't TAudioConverter open Opus files? When i try loading a opus file it won't show up. But when going through "Open" dialogue, Opus is shown as supported.
  • ozok
TAudioConverter
Reply #214
o-l-a-v I'd added an older version of MediaInfo that did not cause problem with saving artwork but now this version does not support opus input. I'll try to find a solution.
  • Last Edit: 13 February, 2013, 07:12:23 AM by ozok
  • ozok
TAudioConverter
Reply #215
fhgaacenc.exe requires enc_fhgaac.dll (winamp\plugins) , libmp4v2.dll (winamp folder) and nsutil.dll (winamp folder) too.
  • lvqcl
TAudioConverter
Reply #216
qaac supports 6-channel input.
  • ozok
TAudioConverter
Reply #217
Update:
-Added: Support for WavPack
-Added: Empty tag fields will not be replaced with "Unkown" (thx to o-l-a-v)
-Added: More tag fields for MPC, Qaac and ALAC (thx to o-l-a-v and cyberdux)
-Added: A log showing deleted files
-Fixed: A bug where duration info for encoding was calculated wrong
-Fixed: Opus files could not be opened (thx to o-l-a-v)
-Fixed: TAC tried to open output folder even if "Same as source" is checked (thx to detmek)
-Updated: MediaInfo to 0.7.61
-updated: Alphacontrols to 8.18
  • o-l-a-v
TAudioConverter
Reply #218
Update:
Sweet.
Don't seem like TAudioConverter can read bitrate and bitdepth from Opus in this version.
When right click > info:
General
Complete name                            : C:\Users\Olav\Desktop\3395371_My_Life_Original_Mix.opus
Format                                  : OGG
File size                                : 4.13 MiB
Duration                                : 5mn 40s
Overall bit rate                        : 102 Kbps
Writing application                      : opusenc from opus-tools 0.1.6-21-g69c4ac8
Comment                                  : TAudioConverter
ENCODER_OPTIONS                          : --vbr --comp 10 --bitrate 100
Audio
Format                                  : Opus
Duration                                : 5mn 40s
Channel(s)                              : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Compression mode                        : Lossy
Writing library                          : libopus 1.1-alpha-39-g10a34a5-babyeater-deluxe
It still reads 5.1 as 6ch. VLC says: 3F2R/LFE (per wikipedia is 5.1), TAudioConverter (and foobar actually) says "Front: L C R, Side: L R, LFE". Or is 5.1==6ch?
Maybe the buttons should be adaptive to size of the window? When making it smaller than half the screen it begins to look odd
It would be awesome with advanced output options, like specifying a folder system, based on different tags in the audio files.
Like: "%artist% \ %year% %album% \ %track% - %title%" ("Nirvana\ 2002 Best of the Best\ 07 - Lithium" for instance)
But thanks for great work! I'm not complaining, only helping you to kill bugs:)
  • ozok
TAudioConverter
Reply #219
In 0.7.8 there is a bug. If you set "Copy tags from source" TAKc.exe gives an error and quits. As a work-around you may disable tag copying when you are converting to TAK.
  • o-l-a-v
TAudioConverter
Reply #220
When adding files, some words in the dialogue that pops up is in turkish i believe?
  • botface
TAudioConverter
Reply #221
Apologies. That did the trick. Works fine now. And it's nice to see you've added Wavpack as an output option - Thanks
  • o-l-a-v
TAudioConverter
Reply #222
Could it be possible to add support for DTS?
  • ozok
TAudioConverter
Reply #223
Actually TAC supports convertion from DTS for a while now. But FFMpeg can only decode core DTS from DTS-HD files (MA or HR). AFAIK there are no free programs that can decode these files themselves. I honestly do not know much about these files, I don't have much samples.
If you have m2ts files, you can try to open them with TAC.
Edit: Yes these words are in Turkish.
  • Last Edit: 13 February, 2013, 05:04:50 PM by ozok
  • o-l-a-v
TAudioConverter
Reply #224
I had MKV with DTS 5.1 inside. Opened, but won't extract or encode to anything :/
Used DTS add for Foobar, that worked flawlessly:  http://www.foobar2000.org/components/view/foo_input_dts
  • Last Edit: 13 February, 2013, 05:49:02 PM by o-l-a-v
