Topic: TAGS: Find all files that match %artist% = %album artist% (Read 1092 times) previous topic - next topic
I tried to figure out to find out what is the easiest way to find all files where %artist% matches %album artist% within foobar2k.
Is there any way?
Thanks,
-Chris
  • BenB
Depends on where you want the info.
%track artist% will return the artist tag when it differs from the album artist tag, but that isn't exactly what you're asking for.
You can use a title formatting/query syntax string such as the following in foobar's library search to return what you want:
"$if($stricmp($meta(artist),$meta(album artist)),true,false)" IS true
You can consult the Title Formatting Reference and Query Syntax Reference for other available options.
  • Last Edit: 10 December, 2012, 07:53:32 PM by BenB
Thanks for the solution.
I did not know the trick with the "" usage within a query.
