Topic: Active subwoofer around €100 (Read 1301 times) previous topic - next topic
  • eamon123
I'm looking to get an active subwoofer for christmas. I was looking at the S80 from Cambridge audio. Is this a good choice? What would you recommend? €150 is my upper limit.
  • Last Edit: 22 November, 2012, 01:57:30 PM by eamon123
  • DVDdoug
I don't know  anything about that speaker, but Cambridge has a good reputation.  Have you heard that sub?  Can you go to a store and listen to some subwoofers?
Every speaker sounds different and there are always compromises.    With a subwoofer, you'd ideally like strong, deep, even-accurate bass reproduction  (assuming you want "high fidelity").  That generally takes a big box with a big driver and a big amplifier (and a good design).
It's hard to get strong-deep bass out of a small driver, so the designer has to choose between smooth bass that rolls-off at the lowest frequencies and "boomy" one-note bass.    The buyer needs  to compromise too, so it's best if you can listen before buying so that you'll be happy with your choice.
