Topic: looking for a mp3 player , can you give some advises? (Read 6583 times) previous topic - next topic
  • francesco
you know what i miss , is a line out
The headphone output makes a perfectly good line out if you turn the volume up.
yes?
to connect to a densen  amplifier , i'm worried to damage it
  • Sunhillow
  • Members (Donating)
No worries, volume to max (and in settings maximum volume = "loud") ist just the normal line out level, only impedance is lower than a usual line out.
Does rockbox decode AAC?
  • skamp
  • Developer
Volume should be set to 0 dB in Rockbox, not the maximum which is +6 dB. And Rockbox decodes AAC, yes.
  • 2Bdecided
  • Developer
yes?
I assume you mean a normal integrated amplifier, or a pre/power combination? If so, yes, it will be fine.
Don't use it with just a power amplifier (i.e. don't use it without a pre-amplifier). At very low volumes the clip is too hissy to be connected directly to a power amplifier, and isn't designed for that anyway.
