Topic: Unrecoverable playback error: Unsupported stream format: 88200 Hz / 32 (Read 1785 times) previous topic - next topic
  • gz00
Can anyone help me get round the above.  Files are 24bit/88,2 kHz FLAC.  I am using WASAPI(push):SPDIF Interface (TX!) (VIA High Definition Audio) via optical cable into Cambridge DACMagic. Output data format set to 32 bit.
All help appreciated. Thanks Gz00
  • Case
  • Developer (Donating)
S/PDIF doesn't support anything higher than 44100 Hz 16 bit stereo. You need to add a resampler and limit bit depth.
  • skamp
See my profile for measurements, tools and recommendations.
  • Rollin
Looks like S/PDIF supports up to 24 bits / 48 kHz.
Really S/PDIF supports up to 192KHz/24 bits stereo on coaxial and up to 96KHz/24 bits stereo on TosLink
192kHz/24bits operation is available on its coaxial S/PDIF input, while 96kHz/24bits can be achieved when using the legacy Toslink input
http://www.m2tech.biz/evo_dac.html
But S/PDIF doesn't support 32 bits
  • Last Edit: 17 November, 2012, 11:43:14 AM by Rollin
