Topic: Samples for LAME 3.100 testing thread (Read 3855 times) previous topic - next topic
  • IgorC
This is the upload thread of samples  for LAME 3.100 alpha testing thread.
The main discussion is here
  • Last Edit: 07 November, 2012, 09:54:59 PM by IgorC
  • IgorC
Tonal sample "Fugue Premikres notes"
  • Dynamic
Also encoding the Transient/Tonal sample "Fugue Premikres notes" I added two further samples:
I performed the same ABX on 3.100.alpha2 but added a comparison with a -V5 and -V5+ encode from the non-Final version of halb27's lame3.99.5y (which still had a -V5+ mode which he had meant to disable).
This is the version I used for the -V5+ sample (UK date & UT/GMT+0 time formatting in Command Prompt DIR command):
08/03/2012  17:36           330,752 lame3995y.exe
and this is the version that disables -V5+ (producing -V5) instead, which I happened to use for the -V5 sample:
16/03/2012  23:52           331,264 lame3995y.exe
For simplicity, I haven't run mp3packer over the -V5+ encode, which came to 139.5kbps versus 113.7kbps for the standard, .
The 2 files encoded by 3.99.5yNotFinal and ABX logs are attached.
For completeness here are the encoder histograms:
for -V5
C:\Users\Ryan\Music\Test signals>lame3995y.exe -V5 "Fugue_Premikres_notes\Fugue
Premikres notes.wav" .\sample09_3.99.5y_V5
LAME 3.99.5y 32bits (http://lame.sf.net)
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
Encoding Fugue_Premikres_notes\Fugue Premikres notes.wav
     to .\sample09_3.99.5y_V5
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=5)
   Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
   352/352  (100%)|    0:00/    0:00|    0:00/    0:00|  16.275x|    0:00
 32 [  0]
 40 [  0]
 48 [  0]
 56 [  0]
 64 [  0]
 80 [  0]
 96 [ 80] %%%%%%%%%%%%%%%%***********
112 [209] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%**********************
128 [ 51] %%%%%%%%%%%%%%%**
160 [  4] %%
192 [  3] %
224 [  3] %
256 [  2] %
320 [  0]
   kbps        LR    MS  %    long switch short %
  113.7      69.0  31.0        96.4  2.0  1.6
Writing LAME Tag...done
ReplayGain: +7.7dB
############### deletia #############
and for -V5+
C:\Users\Ryan\Music\Test signals\lame3_99_5y_not_final>lame3995y.exe -V5+ "..\Fu
gue_Premikres_notes\Fugue Premikres notes.wav"
Encoding ..\Fugue_Premikres_notes\Fugue Premikres notes.wav
     to ..\Fugue_Premikres_notes\Fugue Premikres notes.mp3
   352/352  (100%)|    0:00/    0:00|    0:00/    0:00|  16.132x|    0:00
 32 [  0]
 40 [  0]
 48 [  0]
 56 [  0]
 64 [  0]
 80 [  0]
 96 [  0]
112 [ 13] %%%*
128 [283] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%**********************
160 [ 28] %%%%%**
192 [ 11] %%%
224 [  3] %
256 [  5] %*
320 [  9] %%*
  139.5      69.0  31.0        96.4  2.0  1.6
ReplayGain: +7.7dB
  • Gainless
2 more samples, which are ABXable with -V 2:
[ Attachment Invalid Or Does Not Exist ]
Ringing starting from the first notes.
foo_abx 1.3.4 report
foobar2000 v1.1.16
2012/11/18 13:52:23
File A: C:\...\Desktop\Infected Mushroom - Poquito Mas.flac
File B: C:\...\Desktop\INFECTED MUSHROOM - Poquito Mas.mp3
13:52:23 : Test started.
13:52:41 : 01/01  50.0%
13:52:48 : 02/02  25.0%
13:53:00 : 03/03  12.5%
13:53:08 : 04/04  6.3%
13:53:15 : 05/05  3.1%
13:53:28 : 06/06  1.6%
13:53:36 : 07/07  0.8%
13:53:43 : 08/08  0.4%
13:54:10 : 09/09  0.2%
13:54:24 : 10/10  0.1%
13:54:27 : Test finished.
Total: 10/10 (0.1%)
Pre-echos on the kicks (posted that one to the wrong forum at first).
  • Last Edit: 18 November, 2012, 08:15:36 AM by Gainless
  • halb27
Nice sample, Poquito Mas. Thanks for it. I could ABX 3.100a2 -V2 too.
The significance of samples like these is that it's pretty simple natural music.
lame3995o -Q1.7
opus --bitrate 140
  • Gainless
Another Kick sample which sounds odd with -V 2.
http://www.hydrogenaudio.org/forums/index....showtopic=98132
