Topic: foo scheduler failed (Read 1332 times) previous topic - next topic
I have recently got the foo scheduler and thought I will try this out this morning as an alarm.
I set everything up, I wanted my computer to wake up from hibernation and play a playlist. However in the morning nothing happened. When I started my laptop up it played the playlist right away automatically.
Am I doing anything wrong? I will try to set my laptop to sleep mode tonight. I have intuition that that will work. But I prefer hibernate.
Any ideas?
It works fine for me. Unfortunately, you didn't elaborate on what steps you took so it's somewhat difficult to tell you how/where you failed.
To create the task I simply created an action to start playback. Then I created an event and set it to daily at 9.00 and ticked the box to wake up from hibernation/standby. Then I assigned the action to the event. I left foobar open together with the playlist I wanted to be played. I highlighted the songs (I don't know if that is necessary). Then I hibernated my laptop. I didn't close it in case it wouldn't play the music.
As I mention upon switching my laptop back on in the morning, the music just started playing. It's as if it knew it needed to play but was waiting for the laptop to wake up. Weird. That is why I think stand by is going to work.
