Topic: ColumnsUI scripting help (Read 1891 times) previous topic - next topic
Right now I'm using
function on_playback_seek(time){
    window.Repaint();
To repaint a seekbar. But I would like it to move more smoothly. Is there a way to make it update every millisecond?
Right now I'm using
    window.Repaint();
Edit:
function on_playback_time(Time){
    window.Repaint();
you can in wsh by using a timer
quick way without testing but the goal is to explain you the trick, after, adapt it
// global variable declaration for the timer
var refresh_timer = false;
function on_playback_new_track() {
// on new track, kill the current timer if running (=true), then set a new one with function to execute on each delay reached, below, refresh is set every 250 ms
if(refresh_timer) {
window.ClearInterval(refresh_timer);
refresh_timer = window.SetInterval(function() {
window.Repaint(); // bigger is your panel, more %cpu a repaint will consume, think about window.RepaintRect(x,y,w,h) instead of a Whole Repaint if you seekbar is only a small part of the panel
}, 250);
function on playback_stop() {
// kill the interval timer on playback stop
if(refresh_timer) {
check samples that come with WSH Panel Mod component (in the zip), there are examples, and one for the timers too
HTH
Sorry man, I have no fluency in javascript, I don't know how to fix that, it just crashes. If it's too much to ask to fix it I will try and learn myself... let me know anyway.
Never mind, I got it working! Thanks for pointing me in the right direction. I couldn't have done it without you.
