Topic: Foobar not showing library under Artist, Genre, or Album sub-headings (Read 4348 times) previous topic - next topic
  • .Birch.
As you can see in the picture below, the top 3 columns show nothing under Artists, Genres, or Albums.  I have only one folder being monitored and it contains ~34,000 songs.  The only items shown when I click any of those columns (Artists, Genres, Albums) are files found in my ITunes folder, which shouldn't be monitored in the first place.  How do I fix this?
  • .Birch.
Ignore this post.  I fixed the problem.  For some reasons Foobar kept adding the folder c:/Users/Public to be monitored, even after I removed it several times.  I restarted my computer and it stopped doing this.
  • Last Edit: 23 October, 2012, 01:46:34 PM by .Birch.
  • shakey_snake
  • Moderator
Make sure you use the [OK] or [Apply] buttons in the Preferences dialog when making changes.
elevatorladylevitateme
  • ACo
Sorry to piggyback on this thread....
I am actually having a similar problem, however when I changed the path to monitor my folders, for some reason my artists filter seems to not display the artists (just "?Artists" -- not sure what that means), however the albums filter does display all the albums which I am monitoring....any thoughts?  Thanks!
  • ACo
OK after messing around with it enough I eventually figured it out.  Sorry.
