Topic: how do I contact foobar 2000 devs ? (Read 2470 times) previous topic - next topic
  • that guy
due to the nature of these files it is best to send them over email
but no contact adress is provided
  • Alexxander
Post in this forum and describe with details the problem. Try to add as much relevant information you can. I suppose you've read the terms of service (forum rules).
  • db1989
  • Global Moderator
You could try PMing ‘the’ developer: http://www.hydrogenaudio.org/forums/index.php?showuser=84
But yes, it might help to describe your problem here and not confine everything to private discussion. I presume you are referring to files you want to use as examples but which cannot be split to meet our 30-second rule, in which case that doesn’t stop you from discussing the mechanics of the issue here; that means that it will be visible to other users who might also be experiencing or would otherwise benefit from an exposition of the issue.
  • Last Edit: 18 October, 2012, 09:30:11 AM by db1989
  • that guy
foobar2000 is my preferred  music player
I was wondering if some elments of the program such as the filter and equalisation could be ported to a android applcation
I have some draft pictures and a text doument describing the graphical user interface and functionality concepts
