Topic: How to make Album List smaller? (Read 805 times) previous topic - next topic
  • thoed
I wanted to make the Album List smaller (vertically) than the 13 lines of results that it provides and it's impossible. Is there a way to do it without changing over to columnsUI? Sorry is this has already been discussed elsewhere.
[EDIT] I think I posted in the wrong forum. argh. How do I move/delete my topic?
  • Last Edit: 12 October, 2012, 01:40:01 PM by thoed
  • foosion
  • Moderator
There is no way to make the size of the Album List smaller than its built-in minimum. If the right people notice your topic the minimum might be lowered in a future release.
Only a moderator can do this. I moved your topic to the general forum and also changed the title to match the content of your post. I hope you agree with the change.
http://foosion.foobar2000.org/ - my components for foobar2000
  • thoed
Thank you so much. I'll hope for a change in a future version than.
  • BenB
It's minimum size is fairly small now. You could remove it from your layout and just use Library > Album List to open it as necessary. You can also bind that to a button or keyboard shortcut.
