Topic: Stereo to mono mix (Read 1595 times) previous topic - next topic
  • Jason2012
Stereo to mono mix
I want to mix some stereo mp3's to mono to listen with headphones because I only have hearing in one ear. I tried Audacity and Goldwave, and I see they produce different results. Can anyone shed some light on which produces the better mix? Here are screenshots of a couple of files I converted:
Screenshots
Or if you know of another free program that does a good job, please let me know.
  • LithosZA
Stereo to mono mix
Foobar2000 has a built-in DSP filter called 'Downmix channels to mono'. You can keep the MP3s as they are.
Stereo to mono mix
Have you considered a mono mix cord before your 'phones? You wouldn't need to do anything to any program material.
  • bandpass
Stereo to mono mix
Esp. for 60s stuff (seeing that the example track is) you might want to tailor the mix (i.e. choose the percentage of left and right channels to sum) on a track-by-track basis. Any DAW should allow this, and the better mix is the one that sounds better to you.
