Topic: AAC LC encoder (stereo) to AAC LC (5.1) (Read 2940 times) previous topic - next topic
I have AAC LC encoder which support for mono and stereo channel.
I want to convert the existing AAC LC encoder to support 5.1 channel
What are main changes required for AAC LC encoder to support 5.1 channel.
  • C.R.Helmrich
You need to support more than one channel element (SCE, CPE, LFE) within a bit-stream, and make sure you correctly map your input channels to these elements.
Chris
Chris
Thanks Chris,
Please let me know more details like,
Do I need to add LFE encoding module ?
For testing the 6 channel ( that is 5.1) how I create test vector or from where i can get the test vector?
All channel I can encode by using the aac tool ?
where I can more detail about the channel element mapping in bit-stream ?
