Topic: making previous columns visible? (Read 1028 times) previous topic - next topic
  • jannek
hi,
i have a slight problem with my foobar.
the thing is my windows 7 suddenly crashed without any reason and i had to format and reinstall everything. however as i reinstalled foobar i realized the previous columns settings i'd customized in the previous install weren't - naturally - available. in particular i am in need of a 'comments' column where i had written detailed descriptions of my audio files.
as i'm a newbie i have no idea how to retrieve this information. the audio files themselves are exactly as they were before formatting as i managed to save a backup of them before reinstalling windows 7. the problem is i don't know how to gain access to the information contained within those files such as the 'comments' column.
do you understand what i'm talking about? can someone please help me?
thanks
  • tpijag
Assuming
you are talking about seeing the information in a playlist
you are talking about the Default user interface
you are using the default playlist
Preferences>Display>DUI>Playlist View>Custom columns> ADD
name is whatever you want and pattern = %field name you want to see%
in the playlist view, right click on a column header and insert the new column
  • Last Edit: 30 September, 2012, 11:12:07 AM by tpijag
  • Daeron
Right click/Properties on your files to see which tag contains your comments. As tpijag said, you can show its content via '%tag%'.
I'd recommend adding brackets around it, so it won't show an '?' when your tag is empty/doesn't exist: '[%tag%]'
  • Last Edit: 30 September, 2012, 12:36:55 PM by Daeron
  • jannek
Assuming
yes.
yes.
yes.
yes, thanks i got it. thanks a bunch.
  • Last Edit: 02 October, 2012, 10:11:45 AM by jannek
