Topic: Copy all meta data from one flac file to another (Read 3053 times) previous topic - next topic
  • Eli
Is there an easy way to copy all meta-data from one flac file to another?
Quick search hasn't turned up any results.
Is there a reason you can't simply copy the FLAC file itsef?
  • Apesbrain
Drag both files onto Mp3tag.  "CTRL+C" on the source file, then "CTRL+V" on the destination file.  Can also be done on multiple files at once if they are in the same order.
  • Nessuno
This should work (at least on a *nix shell) to copy metadata from a to b:
 metaflac --export-tags-to=- a.flac | metaflac --import-tags-from=- b.flac
... I live by long distance.
  • Eli
The audio is different. One has the meta-data and a bad rip from dBpoweramp. The other has less meta-data, but a repaired rip from CueRipper/CueTools.
  • Dynamic
I've also used foobar2000 to copy all tags in the past:
Right click, Properties on the first track. Select first tag, hold Shift and click last tag. Under Tools/Selection/Copy all selected.
Select second track. Under Properties/Tools/Paste fields.
