Topic: Automatic tagging in foobar (Read 8915 times) previous topic - next topic
  • alexberka
Hello. I have a large amount of vinyl captured files which have no artist/album tagging, but are arranged in a folder structure e.g. /artist/album/track_name. Is there any easy way to map directory structure onto artist and album tagging in foobar without me laboriously having to enter all the text fields?
Cheers
  • Frank Bicking
  • Global Moderator
  • Emerelle
If you pick that option (automatically fill values...) in the next dialog you choose from: Other and insert the path this way $directory_path(%path%)
Then you can write a pattern depending on your folder structure. Keep in mind, unwanted characters can be masked with an empty tag like %%
Hth
  • Frank Bicking
  • Global Moderator
That is not necessary, "file names" includes parent folders (see the documentation above).
  • alexberka
Thanks very much, saved me lot of hassle.
  • Emerelle
Geez Frank, I did not pay attention to that.The preview shows the path as soon as a backslash is entered. Good to know.
