Topic: Looking for VBR 192kbps MP3 Lame.exe command line (Read 4785 times) previous topic - next topic
  • bansheeboy
Hi guys, newbie here! 2 part question
1.Just wondering what command line I should enter to rip my cds to VBR 192kbps using version EAC 3.99.5 and lame.exe ?
I read some threads but still a little confused.
2. What settings does this command line that I found, give me:
-V 0 --vbr-new --add-id3v2 --pad-id3v2 --ta "%artist%" --tt "%title%" --tg "%genre%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr%" %source% %dest%
Any help is greatly appreciated! Thanks!
  • m45t3r
You doesn't need to add --vbr-new anymore (since Lame 3.97 or 3.98 is the default) and -V0 is going to give you a higher bitrate then you want. Actually any true VBR mode can give you a different bitrate then you want, but the target bitrate of -V0 is ~245 kbps and not ~192kbps. -V2 is probably what you want (~190Kbps). See the Wiki for more details: http://wiki.hydrogenaudio.org/index.php?ti...ncoder_settings
For tags you can just let EAC do the job, it's the recommended way. If you really want to use LAME, your command line should be sufficient. More information here: http://wiki.hydrogenaudio.org/index.php?ti...ame#Adding_Tags
  • bansheeboy
Ok so how would I type my command line with -V2?
Could someone post a line to copy/paste? Coz the terminology is over my head somewhat
Thanks!!
  • m45t3r
Thanks!!
Well, using EAC to write tags (remember to tick "Add ID3 tag" on EAC configuration) only this should be sufficient:
-V 2
If you really want to use LAME to write tags:
-V 2 --add-id3v2 --pad-id3v2 --ta "%artist%" --tt "%title%" --tg "%genre%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr%" %source% %dest%
Should work.
  • greynol
  • Global Moderator
-V2 %source% %dest%
Please refer to the EAC/Lame article in or wiki for configuration options.
--vbr-new was necessary for 3.97 but is the default with 3.98. Using the switch with 3.99 will give you an even newer alogorithm.
  • Last Edit: 22 September, 2012, 01:40:12 AM by greynol
