Topic: Zero length gaps in EAC (Read 2507 times) previous topic - next topic
Hi. I noticed that a lot (but not all) of my CDs appear to have zero gaps at all when using the "detect gap" feature of EAC.
Is this normal? The first track generally has a 00:00:02 gap, but all the other tracks have zero length gaps.
  • Last Edit: 19 September, 2012, 04:55:57 AM by pinoniceusagi
  • db1989
  • Global Moderator
Is this normal?
Yes.
Tracks need not have gaps. A length of zero means they don’t.
Is this normal?
Yes.
That is reassuring. Thank you.
Another question:
I read in a EAC setup guide that if all the tracks are reported as having the same gap length, something fishy is going on.
I just ripped a CD where all of the tracks were reported as Pre-gap length  0:00:01.73.
Since the guide said that this was supposedly an error, I re-tried using EACs gap detection methods A, B and C. Same result.
Should I be worried? Here is the log: http://pastebin.com/WzL66JJs
  • greynol
  • Global Moderator
Don't believe everything you read, especially if it's in an EAC guide.
I'll remember!
I assume the log looks alright, then?
  • Dario
It most certainly does.
Great.
I'll just continue ripping my way through the collection then.
Thanks all!
