Topic: Why Join-Stereo decreased the bitrate of 270 kbps (stereo) to 216.4 kb (Read 5567 times) previous topic - next topic
Hi.  I don't speak English
Stereo (270.5 kbps):
However --> Figure 2 (Join-Stereo > Figure 1 (Stereo)
  • m45t3r
Joint Stereo is generally more efficient than pure Stereo (you can read how Joint Stereo works here: http://wiki.hydrogenaudio.org/index.php?title=Joint_stereo). Since you're using a Quality parameter (-V0), the encoder can simple use less bitrate to encode at the same Quality.
Either way, that pictures proves nothing. I would say that the quality of both files are similar, but at such high bitrates both should be transparent.
  • db1989
  • Global Moderator
The point of joint stereo is to decrease the bitrate needed to represent a particular two-channel signal.
Also, we don’t care about pictures. You listen to music with ears, not eyes or any other organ. Number 8 of the rules to which you were directed during registration makes this quite clear.
  • Last Edit: 13 September, 2012, 06:05:38 AM by db1989
  • slks
Forcing simple stereo (-m s) in VBR modes can inflate the bit rate, since it's less efficient than joint stereo. It's that simple.
thx
