Topic: New iTunes, new CoreAudioToolbox.dll (Read 92455 times) previous topic - next topic
  • eahm
Mix3dmessagez, did you by chance read the first post? I've reconverted ~1400 songs, albums don't necessarily get smaller, some get bigger. For sure it's better, Apple likes to improve its components. Let's move on more technical details/issues.
  • Last Edit: 19 September, 2012, 10:57:12 PM by eahm
Yes I have, I was just reporting from my personal findings quicktime itself has been effected by the coreaudio update, and not just the encoder in itunes.
  • Anakunda
So. Can anybody blind listening any differences between older and current CoreAudio or is the bitrate decrease only result of compression optimization?
  • eahm
http://www.hydrogenaudio.org/forums/index....st&p=808650
http://www.hydrogenaudio.org/forums/index....st&p=808666
  • nu774
  • Developer
I noticed two major differences so far:
  • 3ch(C+L+R) AAC encoding is supported on 7.9.8.1. It already works with qaac without modification on qaac side.
  • ExtAudioFileRead() crashes when decoding HE-AACv2 on 7.9.8.1 (this has nothing to do with qaac, though).
  • eahm
Reply #30
Thanks for the info.
Can Apple (or even qaac) convert to HEv2? Is it possible with a specific command line or it's automatic below certain bitrates?
  • Last Edit: 30 October, 2012, 01:16:38 AM by eahm
  • nu774
  • Developer
If it is available, you can probably use "afconvert -d aacp" or something in Mac OS X. I don't have Mac or iOS devices, so I'm not familiar with Apple products at all.
As for qaac, NO (same as iTunes for Windows).
  • eahm
New iTunes 11.0.2.25. CoreAudioToolbox.dll is the same.
  • zqae
Reply #33
The file CoreAudioToolbox.dll is different between QuickTime & iTunes, though version is the same?
iTunes:
File: C:\Program Files (x86)\Common Files\Apple\Apple Application Support\CoreAudioToolbox.dll
File Version: 7.9.8.2
Modified: Monday, January 28, 2013, 13:08:16
MD5: D420904DDF2619DA2A96371B0D4670C9
SHA1: 686334C8CC26B0C79FFBE361455EC2E5841BD4C2
CRC32: BF71EFDD
QuickTime:
File: C:\Program Files (x86)\foobar2000\QTfiles\CoreAudioToolbox.dll
Modified: Thursday, October 11, 2012, 21:56:10
MD5: 8A73BCF073DA081C47C98F16E9805855
SHA1: F40BB960AC8124E191E688E46BF07DBDEADA5D02
CRC32: E4583F09
  • Anakunda
Reply #34
iTunes:
CRC32: BF71EFDD
QuickTime:
CRC32: E4583F09
This is only different timestam making the diiff
  • eahm
Reply #35
iTunes 11.1.1.11 has 7.9.8.3. Nothing changed again.
  • eahm
Reply #36
Can a mod please remove the Topic Description so we can keep it general to every iTunes version?
Please delete this post as well.
Thank you.
edit:
Topic Title: QTFiles (iTunes, QuickTime, CoreAudioToolbox.dll) changes thread
  • Last Edit: 04 October, 2013, 02:10:25 PM by eahm
  • greynol
  • Global Moderator
Reply #37
First come up with something compliant with TOS #6, please.
  • eahm
Reply #38
Please check the edit. Thanks.
  • eahm
Reply #39
New iTunes (11.1.2.31) has CoreAudioToolbox.dll 7.9.8.3. Nothing changed again.
  • IgorC
Reply #40
Apple AAC encoder was already mature since 2005.  I don't think there were any revolutionary changes since then ... and there won't be anymore.
  • eahm
Reply #41
Last change was in April 2013, I don't know if much changes regarding quality, ever since 2006 like you said but I keep track of changes anyway, it doesn't cost me anything reporting here. The audio checksum changes every time there is a number change.
  • testyou
Reply #42
I appreciate the reporting, since I would test a new version if it appears.
  • eahm
Reply #43
New iTunes 11.1.3.8 still 7.9.8.3. Nothing changed again.
  • drSeehas
Reply #44
QuickTime 7.7.4 has CoreAudioToolbox.dll 7.9.8.3.
  • moob2014
Reply #45
New iTunes 11.1.4 and new CoreAudioToolbox.dll 7.9.8.4
but the name of the dll now is "AppleApplicationSupport_CoreAudioToolbox.dll"
and I don't know what changes in this version.
  • Last Edit: 22 January, 2014, 06:57:38 PM by moob2014
  • lock67ca
Reply #46
Odd, I just downloaded new iTunes. Same version number you mentioned, 11.1.4, but I'm getting a different version of CoreAudioToolbox
I'm getting 7.9.8.5 and the name is still CoreAudioToolbox.dll
  • moob2014
Reply #47
I have extract with 7-zip and the name is "AppleApplicationSupport_CoreAudioToolbox.dll", but extract with cmd line the name is correct and for me the version is 7.9.8.4
as you can see here:
  • Last Edit: 22 January, 2014, 08:08:44 PM by moob2014
  • azaqiel
Reply #48
I guess I got the best of both worlds.
iTunes 11.1.4, the file is named "AppleApplicationSupport_CoreAudioToolbox.dll", and the file version/product version for me is 7.9.8.5.
  • moob2014
Reply #49
qaac show as version 7.9.8.5 but is not, the file version for me is 7.9.8.4
  • Last Edit: 22 January, 2014, 08:12:27 PM by moob2014
