Topic: Having problems converting FLAC to mp3 (Read 5475 times) previous topic - next topic
  • theflesh
Hi- I'm new and not sure where to post this.  I am trying to get to know foobar2000 as I have heard it is an excellent proram.  I've been following a guide to help me set it up.  I got to the part where it says to go ahead and convert the FLAC.  I right-click and go to convert.  The quide I'm using says the first time I do this it shold ask where LAME.exe is.  However, it does not, so I can't tell it where it is.  It therefore converts the FLAC into... a FLAC.  I have looked all over for some place to add LAME.exe and have been unsuccessful.  Any help would be greatl appreciated.
'Ol Fleshy
I would add the lame.exe file to the main program folder:
C:\Program Files (x86)\foobar2000 - for the 64 bit version of Windows
or...
C:\Program Files\foobar2000 -- for 32 bit
  • eahm
or...
The other way.
By the way, foobar2000 doesn't come in 64bit, the installation is always 32bit in "\Program Files (x86)\"
  • Last Edit: 11 September, 2012, 10:45:20 PM by eahm
The 64 bit version of Windows creates a second “Program Files” folder for 32bit programs. Anything that goes into "\Program Files (x86)\" is a 32bit application. Foobar2000 is a 32bit program. Hence, its program files are located in that folder. There is no need for this second “Program Files” folder in the 32bit version of Windows. But I had no way of knowing which version the OP was using, so I listed both.
Of course, neither of this is relevant to the topic.
  • eahm
Understood your reply now, sorry working in IT and used to most clients I read your comment in a completely different way that you meant it.
  • Last Edit: 11 September, 2012, 11:45:39 PM by eahm
  • db1989
  • Global Moderator
Since you are using foobar2000, its General subforum would have been a logical place. Moved accordingly.
