Topic: Does operating system matter for converting to MP3s? (Read 9949 times) previous topic - next topic
  • fann4ples
I've got a question regarding operating systems: I've been using Foobar and LAME on a Windows Vista to encode my FLAC files to MP3s...
Now would those MP3 files being produced on my Windows Vista computer be any different than if I had done it on Windows XP or 7? (Given that I am using the same versions of Foobar and LAME) Would they be exact copies (size/bits/samples/etc)?
Does the operating system have any influence on the conversion process? Or is that all the work of the program(Foobar and LAME)?
Thank you for your help!
  • ron spencer
It won't make a difference...unless your OS is full of viruses.
  • benski
  • Developer
Different processors might produce subtly different results because of compiler optimizations and the inexact nature of floating point.  You might also run into subtle differences between 32-bit and 64-bit builds of LAME.  These will not result in any audible quality differences, but there is no guarantee that two computers using the same version of LAME will create bit-identical files.
  • Last Edit: 11 September, 2012, 07:48:54 PM by benski
  • fann4ples
So would using a new OS like Windows 7 or 8 result in the files being written in a better way? Would it result in smaller files wit a more efficient codes or something along those lines?
  • Last Edit: 11 September, 2012, 08:19:16 PM by fann4ples
  • benski
  • Developer
No, not at all.
  • krafty
My experience is that enconding with LAME 32/64 bit either under Windows 7 or Red Hat Linux renders a different file but the differences are because of besnki already said: compilers optimizations and nature of floating point. I wouldn't worry, the quality is the same. The same happens for some FLAC files under some Linux systems, they differ a bit than the files created in Windows counterparts, even applying the same compression level.
  • fann4ples
Thanks! I'll try not to worry so much about these little things.
