Topic: fb2k loses the stream when /playpause (Read 1147 times) previous topic - next topic
  • sureoffa
Hi there!
I listen only to stream radio and I'm using AutoHotkey to trigger foobar2000.exe /playpause.
Problem is: lots of times I do /playpause in order to answer a call, etc. and when I do again /playpause it resumes the current stream for like 10 seconds and then jumps to the next station in my playlist.
I think foobar2000 forgets to take on the stream again if playback is paused after like two minutes or more.
I just want to keep playing my stream. How can I approach this issue ?
  • fuflo
Pausing a stream is kind of strange.. Foobar reads the stream to buffer until it fills up i guess, then after unpause it plays the buffer but the stream is cut off so a 'not found' error is given or something. It was discussed at some other thread i believe.
For your specific situation i would suggest using "foobar2000.exe /command:mute" instead.
  • sureoffa
Thank you for your response.
I think is an usability bug because even if a stream technically can not be paused, for the listener the action play/pause should be transparent. The code should evaluate the resume playback function and retake the stream once play is trigged.
command:mute is great, but it makes me create another binding in order to start foobar2000.
Best regards.
  • Forfit
I subscribe it.
