Topic: Echonest fingerprinting (Read 2136 times) previous topic - next topic
The script: view  download
Req:
1. SoX
2. ENMFP_codegen (just unpack codegen.dll and test.exe from Release folder somewhere)
Script expects audio file path, then SoX decodes it to single channel 22k raw file which is than passed to test.exe (it does not accept feeding from stdin unfortunately, so small, 20 sec, temp file is created and deleted afterwards. After test tool provides code sequence, track is identified through echonest api requests.
For formats not supported by SoX, suitable decoder can pipe data to SoX obviously
Correct path to sox.exe and test.exe needs to be set inside script
More about this fingerprinting tool can be read here: http://notes.variogr.am/post/27796385927/t...e-echo-nest-faq
In action:
- from console (verbose is set to 1 which is not the default)
- from foobar2000 as run service
Additionally track ID can be retrieved for querying more services: http://developer.echonest.com/docs/v4/index.html#rosetta
They claim 35 M unique track database and future musicbrainz interoperability (http://echoprint.musicbrainz.org)
