Topic: [derp] From: Audio from vinyl (24 / 96-192 khz). Converting/downsampli (Read 652 times) previous topic - next topic
  • db1989
  • Global Moderator
Vinyl itself can usually be recorded transparently with 12 or13 bits and 32-36 KHz sampling.
Logic and context tell me that you meant 16–18 kHz.
  • Last Edit: 28 August, 2012, 01:00:03 PM by db1989
  • saratoga
Did you misread 'sampling' as 'lowpass'?  :confused:
  • greynol
  • Global Moderator
Maybe you need to break-down and get yourself an avatar of a cat.
I meant 32-36 KHz sampling for which the Nyquist frequencies are 16-18 KHz. So yes,we are describing the same bandpass two different isomorphic ways.
  • db1989
  • Global Moderator
Haha, sorry.  I’ll have to hope that ‘It was a long day’ is a sufficient excuse!
