Topic: Optimal bitrate AAC-HE v2 [eAAC +] (Read 3880 times) previous topic - next topic
  • Stranix
Good day.
What is the optimal bitrate to choose the correct encoding and playing format AAC-HE v2 [eAAC +], what is the maximum possible bit rate for this format.
  • saratoga
AAC-HE V2 seems to work best for very low bitrates, usually less then 64kbps IIRC.  For higher bitrates, normal HE or LC AAC often performs better.  There have been listening tests done on these forums before testing it, you may be interested in reading those results.
  • Stranix
Please link to these tests can be
  • db1989
  • Global Moderator
We have an entire subforum called Listening Tests.
Or there’s a Google box at the top-right, which might help find announcements that were placed in News rather than the former.
example
  • subinbar
Is there a low-bitrate codec listening test planned for the near future?  Like ~24-48kbps?
