Topic: Windows 8 has a new audio system! (Read 3300 times) previous topic - next topic
  • PelPix
Just installed the Windows 8 RTM.  At first, I was really angry.  Apparently MS wrote an updated, smarter kernel scheduler and my audio was jerky because it kept interrupting the stream because my ASIO driver was for windows 7 and wasn't coded for the new interrupt code.
Then I begrudgingly tried WASAPI.  After various tests, I can verify that it's now totally bit-perfect.
If that wasn't awesome enough, there appears to be a completely new DirectSound server!  When playing 20-48khz sine wave sweeps at 96kS/s with the output set to 44.1S/s, there is no aliasing!
  • Last Edit: 15 August, 2012, 11:06:02 PM by PelPix
This sounds really interesting. I have tried the release candidate and working with Metro I felt like a senior trying out a computer for the first time but I have high hopes for it. Regards.
Windows 7 WASAPI Shared is also absolutely bit perfect (if processing is completely disabled and samplerate in Control Panel is set appropriate to audio's samplerate).
(Playback: foobar2000/Primary Sound Driver, Recording: Creative ASIO/MIX FL/FR)
  • Last Edit: 16 August, 2012, 04:26:02 AM by Steve Forte Rio
Downsampling (96->44.1) in Windows 7 is also not so bad:
And finaly, as I see, new Windows' sound engine has absolutely no differences from it's previous implementation.
  • Last Edit: 16 August, 2012, 04:24:54 AM by Steve Forte Rio
  • PelPix
WASAPI isn't much different under the hood, but the point is more that it's all automatic now and that DirectSound is no longer so low-fidelity.
