Topic: EAC to FLAC (Read 2152 times) previous topic - next topic
  • norlane
EAC to FLAC
Following this guide
http://blowfish.be/eac/Setup/setup4.html
Using eac-1.0beta3 trying to configure to encode to FLAC.
Added
Compression Options/External Compression
Additional Command Line Options: Select, then copy this line, and paste into the box in EAC:
-V -8 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
Getting Error when click OK.
Invalid replacement tag found
Can some one tell me what is wrong with this and what is the best cmd line to use.
I read some forum posts and noted this comment. Is this a good line to use.
Sorry i am new to this and just want to run the program before i nut down into the syntax here.
QUOTE:
If you are encoding to FLAC, default commandline options are:
CODE
-6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
Can some one link me to some good tutorials EAC to FLAC / MP3 ect.
thankx in advance for any help
EDIT found this page:
http://wiki.hydrogenaudio.org/index.php?title=EAC_and_FLAC
should i use this
  • Last Edit: 15 August, 2012, 04:56:00 AM by norlane
  • greynol
  • Global Moderator
EAC to FLAC
  • bluto
EAC to FLAC
Hello Norlane,
Some of the online guides around are sadly out of date, and use %s rather than %source%.
%s  was the source placeholder in earlier versions of EAC. I believe that from 1.02b onwards, you now need to use  %source% as the placeholder.
I may be wrong, but I think that the  -o %dest% is not needed. My own code just has this:
-V -8 %source%
(All my tagging is done afterwards in Mp3Tag)
Hope this helps,
Bluto
  • norlane
EAC to FLAC
thankx for this yes reading the above link it look like you are spot on  thankx
    If you are using EAC 1.0b2 or newer, then in the Additional command line options box, copy and paste the following string:
-T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" -5 %source%
  • Last Edit: 16 August, 2012, 08:25:30 PM by norlane
  • bluto
EAC to FLAC
Actually, you may as well use -8 instead of -5 for the compression.
8 is the best compression (smallest file size), and on modern PCs it isn't that much slower than 5.
I also use the -V option for peace of mind. I believe this verifies the file at the end, checking there are no compression errors. It may well be redundant now after all this time, however. (I don't think that Flac 1.2.1b ever produces an error when compressing a file, but just in case it would be nice to be notified.)
Bluto
  • greynol
  • Global Moderator
EAC to FLAC
-8 buys you little compression over -6; less than 1% IIRC.
I have seen -V fail to catch an error, so recommending it out of paranoia is a fool's errand.
