Topic: quality loss in converting to WAV? (Read 2002 times) previous topic - next topic
  • atdi198d
i was just wondering if there was any loss in quality if i converted a wav to wav, or aac to wav, or mp2 to wav.
i'd be using audacity to edit wavs, aac, mp2, or mp3, and then exporting it as a wav as i know for sure that if you export it again as an aac, mp2, or mp3 you'd lose quality.
thanks in advance
  • 4sure
As long as you don't change (down grade) parameters, like bit depth, the conversion has no effect.
"In the beginning was the Audiophile"
  • atdi198d
all i'd be doing is splitting one big wav, mp2, aac, or mp3 into seperate tracks using audacity and then exporting it right away.
or converting it without splitting with audacity. does either of those change the parameters? how can i check this myself?
  • [JAZ]
The only thing worth mentioning with Audacity is the default bitwidth and its usage of dithering (See edit->preferences->quality). For your intended usage, use the same bitwidth than the original, and do not use dithering.
Btw, if you have a .cue file for those files, maybe an even easier way to split them would be to use foobar200, and its converter.
  • Last Edit: 11 August, 2012, 01:16:40 PM by [JAZ]
