Topic: audio comparator tool (Read 2247 times) previous topic - next topic
hi guy,
i need a software that can use to compare 2 sound waves file. 1 is generated sound wave and another is received sound wave, to check whether the usb device are reliable to transmit the audio file.
do u guys have any suggestion on that?
p/s : is better that the software provide with the feature that indicate that the sound waves that I'm testing whether " Pass or Fail"
thanks
  • Kohlrabi
  • Global Moderator
foobar2000 with foo_bitcompare can do the job.
hi. how do i do that. i alrdy hav foobar. do i need manually install the feature ? or it already inside foobar?
thanks
  • probedb
thanks
You did click on the link and read the documentation didn't you?
  • bandpass
It depends on the device: if your USB device is 'transmitting' the file digitally (e.g. USB wifi/3G dongle), then any file comparison tool will do the job.  If there's processing involved, (e.g. a looped-back USB audio interface), then you'll need a tool like Audio Diffmaker
hi thanks... there is looped-back interface involved.
any other tools u can recommend except the audio diffmaker?
thanks
  • bandpass
The other that springs to mind is RMAA
thanks bro. please dont hesitate to update here if u thinks of any other tools.
many thanks
  • phofman
IMO the task always involves aligning samples of the two tracks. Is there a simple utility to help with this chore? I know only about http://axel-sommerfeldt.de/wavdiff001123.zip (incl. source code) or http://asp.lionhost.ru/en/tools_wavdiff.html (closed source).
  • Garf
  • Developer (Donating)
The AFsp toolsuite includes CompAudio, which allows to do this, and search for the delay. Google for AFsp audio and you'll find it. (It's open source as well)
  • phofman
Thanks for the hint, I did not know about AFsp toolsuite.
i need something like fourier rocks. anyone have any idea?
