Topic: LOADING playlists not working (Read 775 times) previous topic - next topic
I just upgraded to 1.1.13.
After a playlist is loaded, and I want to open/load a new playlist, I see the new playlists tracks in the location window, but when I hit play, it still plays the former track.
I must close, then reopen FB, then load the playlist to get it to play.
How can this issue be fixed?
You could just double-click on the track where you want playback to begin, instead of using the Play button.
Or, enable "Playback follows cursor" in the Playback menu. With this option enabled playback should start in the newly loaded (and therefore focused) playlist. Though with it enabled you must be mindful not to unintentionally change your desired playback order by highlighting other tracks.
