Topic: Checkboxes, buttons in playlist viewer? (Read 679 times) previous topic - next topic
  • ViniMan
Is it possible to make some sort of checkbox or a button in the playlist view next to each song? (The checkbox representing a certain true or false value in the ID3 tags..)
E.g. you want to check tracks you should listen again and you tick the box..
thanks
  • ruebe
there is a multitude of options, if you want something as simple as check-boxing, but check-boxing itself is not possible
the closest thing you could do, would be using esplaylist...there you can rate your sings in-line via clicking, which might provide the functionality you want
