Topic: Fighter Beat looped (killer sample) (Read 75987 times) previous topic - next topic
Small piece of Fighter Beat track, looped several times. It kills all lossy codecs on all beatrates.
It's not enough to say it, you need to provide ABX logs in order to comply with our terms, especially when making incredible claims like the one you just made.
BTW what's a beatrate?
There was a thread where this track was mentioned: http://www.hydrogenaudio.org/forums/index....showtopic=57783 , posts 10-14
Yes, I know. I just looped the most hard for encoders part of it, so that the difference can be heard more clearly.
My iRiver player does not support lossless, so I use Vorbis q10, and I can hear the difference between it and Vorbis Q9, Musepack q10 and Nero AAC Q1 (max. bitrate). It looks like converted tracks sounds slightly quieter, almost indistinguishable. Dont know why, but on PC it is harder to hear this difference (maybe because it is AC97?). Probably, I should try test it more strenuously.
Anyway, this sample is the best I could find for testing audio codecs for myself, and I hope people who make listening tests pay attention to it.
LOL, the same as Fighter Bit.
I quickly tested(Not ABX) the sample with Vorbis at 160Kbps and Opus at 160Kbps CVBR.
The Vorbis encode sounds very different from the original. With the Opus encode I don't know if I am actually hearing a difference or not. I probably will have to do an ABX.
I quickly tried both Nero from 7-Feb 2006 using -q 0.3 -lc and Lame 3.98.4 -V3 and do not believe I would be able to pass an ABX test.
Same here; files I produced with these parameters all sound alike to me:
Oggenc 2.87/libVorbis 1.3.3 -q 0.5 [same as -b 160]
NeroAAC 1.5.1.0 -q 0.57
LAME 3.99.5 -b 320
Fraunhofer MP3S 1.5/lib4.01.01 -br 320000 -q 1
So yeah, "kills all lossy codecs on all btrates" is an overstatement. I have to question the reports in the aforementioned thread as well.
@softrunner - Please take the time to run ABX tests in foobar2000. In the meantime, I suggest this thread be retitled by an admin to just "Fighter Beat loop" with the subtitle "possible problem sample for Ogg Vorbis encoder; ABX testing needed". Or something along those lines.
5/5 first time with both LAME -V4 and Vorbis -q5, both the most recent rarewares releases. I actually got LAME backwards, 0/5, but I could tell the difference. The encode sounded marginally better than the original to me... >_>
Never thought that such a regular sample could be that badass. Encoding with lame -V0 gives a bitrate of 314, so it certainly knows it is up against something. I've never seen anything like that.
Some of my highest-bitrate FLACs, do end up between 245 and 255 when lame -0'ed. Including the least-compressible harpsichord piece I have.
In the lossless department: TAK -p4m encodes at 1037.  FLAC -8 encodes at 978, that's 5.7% better. WavPack extra high at 837. That's a 14.5 percent better than FLAC -8 and 19 percent better than TAK -p4m.  I have never before seen any sample where TAK -p4m is beaten by 200 kb/s.
Ok, now I've done an ABX test of MP3 on PC, because MP3 is too obviouse to recognize.
Codec is LAME3.99. Original file was converted into MP3 320 kbps (maximum quality) with Foobar2000:
foo_abx 1.3.4 report
foobar2000 v1.1.13
2012/07/21 01:31:58
File A: S:\320 GB HDD\Аудио-тесты\NEW\Fighter_Beat_Loop.wav
File B: S:\320 GB HDD\Аудио-тесты\NEW\Fighter_Beat_Loop.mp3
01:31:58 : Test started.
01:37:11 : 01/01  50.0%
01:39:35 : 02/02  25.0%
01:55:14 : 03/03  12.5%
01:57:05 : 04/04  6.3%
01:59:20 : 05/05  3.1%
02:01:50 : 06/06  1.6%
02:04:59 : 07/07  0.8%
02:08:29 : 08/08  0.4%
02:09:40 : 09/09  0.2%
02:13:03 : 10/10  0.1%
02:16:46 : 11/11  0.0%
02:18:15 : 12/12  0.0%
02:19:17 : 13/13  0.0%
02:20:25 : 14/14  0.0%
02:23:11 : 15/15  0.0%
02:23:46 : 16/16  0.0%
02:25:42 : Test finished.
Total: 16/16 (0.0%)
The difference in files is that in the original sample there is a sharp background scratch, and in the mp3 sample it is smoothed so that I just cannot here this information there.
Here is another test:
Vorbis Q7 (333 kbps)
foobar2000 v1.1.14 beta 1
2012/07/22 20:38:10
File A: S:\320 GB HDD\Аудио-тесты\NEW\Converter\input\Fighter_Beat_Loop.wav
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\Fighter_Beat_Loop (Vorbis q7).ogg
20:38:10 : Test started.
20:38:57 : 00/01  100.0%
20:39:15 : 01/02  75.0%
20:39:57 : 02/03  50.0%
20:40:07 : 03/04  31.3%
20:41:05 : 04/05  18.8%
20:41:44 : 05/06  10.9%
20:42:25 : 06/07  6.3%
20:42:45 : 07/08  3.5%
20:43:44 : 08/09  2.0%
20:45:22 : 09/10  1.1%
20:46:22 : 10/11  0.6%
20:48:02 : 11/12  0.3%
20:48:55 : Test finished.
Total: 11/12 (0.3%)
The same story: no sharpness in the background noise (right channel).
Have you tried Opus with this sample?
Vorbis q8 (bitrate 376 kbps):
2012/07/22 21:01:15
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\Fighter_Beat_Loop (Vorbis q8).ogg
21:01:15 : Test started.
21:02:51 : 01/01  50.0%
21:03:28 : 02/02  25.0%
21:05:15 : 03/03  12.5%
21:05:52 : 04/04  6.3%
21:06:21 : 05/05  3.1%
21:07:00 : 06/06  1.6%
21:08:19 : 07/07  0.8%
21:08:46 : 08/08  0.4%
21:09:16 : 09/09  0.2%
21:10:01 : 10/10  0.1%
21:10:24 : Test finished.
Total: 10/10 (0.1%)
I'll do it later.
Provide results for mpc and aac and I think we've got our bases covered.
Musepack q8 (350 kbps)
2012/07/23 03:16:51
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\Fighter_Beat_Loop (Musepack q8).mpc
03:16:51 : Test started.
03:17:42 : 01/01  50.0%
03:18:15 : 02/02  25.0%
03:18:29 : 03/03  12.5%
03:19:18 : 04/04  6.3%
03:19:48 : 05/05  3.1%
03:20:04 : 06/06  1.6%
03:20:40 : 07/07  0.8%
03:21:03 : 08/08  0.4%
03:21:34 : 09/09  0.2%
03:22:03 : 10/10  0.1%
03:22:13 : Test finished.
Total: 10/10 (0.1%)
Nero AAC q0.9 (374 kbps)
2012/07/23 03:36:14
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\Fighter_Beat_Loop (Nero AAC q0.9).m4a
03:36:14 : Test started.
03:37:01 : 01/01  50.0%
03:38:30 : 02/02  25.0%
03:40:04 : 03/03  12.5%
03:41:25 : 04/04  6.3%
03:42:28 : 05/05  3.1%
03:44:08 : 06/06  1.6%
03:45:40 : 07/07  0.8%
03:47:36 : 07/08  3.5%
03:48:16 : 07/09  9.0%
03:48:52 : 08/10  5.5%
03:49:19 : 09/11  3.3%
03:50:36 : 10/12  1.9%
03:52:06 : 11/13  1.1%
03:53:02 : 12/14  0.6%
03:53:29 : Test finished.
Total: 12/14 (0.6%)
It looks like the amplitude of a saw-like sound in aac sample is lower than in an original one.
Please reassure me that I'm reading this wrong, or somehow out of context.
Creature of habit.
I couldn't ABX lame -v2.  But its a hard sample (for me at least) because its so noise-like.
Looking at it in the time domain is very interesting though.  With the lowpass disabled, the time domain versions of the MP3 and lossless look nearly identical, with just a tiny bit of extra quantization noise in the lossy version.  I would have expected the impulses to give the transform more trouble, but that doesn't seem to be the case.
I can't do it with AAC at v-5.
Error 404; signature server not available.
This is just the turn of speech. What I meant is that the wavy signal, that sounds like a power-saw, in AAC has less max. volume than in the original sample.
Opus 192 kbps (289 kbps in real) (libopus 0.9.11-119-g1a50ad0-exp_analysis)
(Converted via "opusenc.exe --music --bitrate 192")
2012/07/23 15:42:38
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\Fighter_Beat_Loop (Opus 192 kbps).opus
15:42:38 : Test started.
15:43:31 : 01/01  50.0%
15:44:57 : 01/02  75.0%
15:45:39 : 02/03  50.0%
15:46:22 : 03/04  31.3%
15:48:02 : 04/05  18.8%
15:48:25 : 05/06  10.9%
15:48:51 : 06/07  6.3%
15:50:28 : 06/08  14.5%
15:50:56 : 07/09  9.0%
15:51:55 : 08/10  5.5%
15:53:07 : 08/11  11.3%
15:54:06 : 09/12  7.3%
15:56:30 : 10/13  4.6%
15:58:24 : 11/14  2.9%
15:59:46 : 12/15  1.8%
16:03:34 : 13/16  1.1%
16:03:39 : Test finished.
Total: 13/16 (1.1%)
You can focus your eyes on some object, but the most information still comes from peripheral seeing. The same in hearing. Dont try to focus on particular sounds, otherwise you will miss the most information. That's how I do it: just trying to listen via unfocused peripheral hearing, and the sound shows its difference itself.
Now I'm getting curious: can you nail down a freeformat@640?
2012/07/23 15:42:38
File A: S:\320 GB HDD\?????-?????\NEW\Converter\input\Fighter_Beat_Loop.wav
File B: S:\320 GB HDD\?????-?????\NEW\Converter\output\Fighter_Beat_Loop (Opus 192 kbps).opus
I haven't  used Windows in years. But from what I read here, fb2k outputs Opus files at 48000Hz.
So, how does foo_abx handles files with different sample rates?
Or is that irrelevant because the audio reaching the output device is mixed with a certain sample rate supported by the device?
If you mean "lame.exe --freeformat -b 640 *.wav", I cannot find how to decode it. Anyway, it must be useless.
If you decode it into wav, it will be 44kHz, so I think it is ok.
Musepack q9 (382 kbps)
2012/07/23 20:17:12
File A: D:\@Portable@\Audio\@Encoders@\test.wav
File B: S:\320 GB HDD\Аудио-тесты\NEW\Converter\output\test (Musepack q9.0).mpc
20:17:12 : Test started.
20:19:18 : 01/01  50.0%
20:20:50 : 02/02  25.0%
20:21:50 : 03/03  12.5%
20:23:14 : 04/04  6.3%
20:27:34 : 05/05  3.1%
20:28:29 : 06/06  1.6%
20:29:12 : 07/07  0.8%
20:35:04 : 08/08  0.4%
20:35:52 : 08/09  2.0%
20:37:59 : 09/10  1.1%
20:41:08 : 10/11  0.6%
20:41:12 : Test finished.
Total: 10/11 (0.6%)
No, Opus will not decode at 44100 Hz by default. 2012 is correct; please actually read what people say, rather than just waving it away.
I presume foo_abx intelligently resamples, probably both files to a common rate (the higher of the two?); I would certainly welcome confirmation.
Anyway: Thanks for all the tests! They make TOS #8 happy.
Opusdec will decode at 44.1kHz, if the opus file was sourced from a 44.1kHz WAV. Maybe that's what softrunner meant.
