Poll
Poll 1º
  • Rock (Rock, Metal, Punk etc.)
    179 (22.6%)
  • Pop
    84 (10.6%)
  • Classic
    103 (13%)
  • Hip-Hop, Rap
    45 (5.7%)
  • Jazz
    73 (9.2%)
  • Electronic
    118 (14.9%)
  • Country
    28 (3.5%)
  • Blues
    50 (6.3%)
  • Reggae
    33 (4.2%)
  • OTHER (see Poll 2º)
    78 (9.9%)
Total Members Voted: 287
Topic: What music genres do you listen to? (Read 27665 times) previous topic - next topic
  • IgorC
It would be useful to see what the most popular music genres are.
I've taken into account this discussion to create the list of music genres .
Share your thoughts
Please, pick the genres which You listen mostly. An occasional listening of some particular genres doesn't count.
  • Last Edit: 16 July, 2012, 02:01:06 AM by db1989
  • JJZolx
I have to ask: Useful for what?
  • ojdo
Please put this phrase into the question of the poll. I answered thoroughly just to be told that I should have answered a different question.
  • eahm
Classical, Pink Floyd, Minimal Techno.
I did not vote since Classical is not available.
  • Last Edit: 15 July, 2012, 11:40:25 PM by eahm
  • db1989
  • Global Moderator
As this doesn’t really fall under the scope of General Audio, I’ve moved it to Polls; I thought that was a better compromise than General Music Discussion, seeing as topics within the last are not featured on the Portal by default. Is this relevant to a future listening test or something similar?
Edit:
Done.
  • Last Edit: 16 July, 2012, 01:59:41 AM by db1989
  • onkl
Rock, Pop and Electronic are so broad terms.
  • Porcus
I guess my “occational” listening to a genre involves more hours than the average person's main interest. (At least as long as you don't count as “listening” the idiot box that is constantly switched on.)
  • Last Edit: 16 July, 2012, 08:38:59 AM by Porcus
  • IgorC
Bitrate varies considerably per genre.
The results of this poll can be useful for bitrate verifications during preparation/discussion of  public tests as well as for developers (calibration of VBR modes, optimization of compression etc.)
  • Last Edit: 16 July, 2012, 12:06:11 PM by IgorC
  • db1989
  • Global Moderator
Is that suggesting that developers should make accommodations (of what nature?) for particular genres, rather than remaining objective and fair by sticking with universal principles of psychoacoustics? If so, I'm not sure how to feel about that!
This assumes such tunings are even possible/worthwhile. The closest example I can think of is work to reduce SFB21 bloat, which may be more relevant to fans of genres that tend to be treble-heavy, but which seems to me to be ultimately an issuethat is more general and whose amelioration is beneficial across the board.
  • IgorC
Any audio codec has a "difficult" and  "easy" genres to compress. The information about  average collection (roughly speaking) helps to determine how much encoder can increase or decrease bitrate on some particular genres and still would hit desired bitrate on big variety of genres.
  • Last Edit: 17 July, 2012, 12:12:37 AM by IgorC
  • hlloyge
Krautrock, Disco - mostly.
If you want to know the top listened genres, just look at the top tags listed at last.fm,
i.e http://www.last.fm/music.
On left column:
acoustic
ambient
blues
classical
country
electronic
emo
folk
hardcore
hip hop
indie
jazz
latin
metal
pop
pop punk
punk
reggae
rnb
rock
soul
world
60s
70s
80s
90s
I  think ambient is a major omission from poll.
  • GeSomeone
So do I. BTW in stead of Ambient I voted Experimental.
As for the discussion, it makes no sense to me that a compiler should even know what the genre is. What I can think of is that you make a couple of encoding pre-set that you think is right for certain genres. But VBR makes that not worthwhile either. I see it as a "Just for fun" poll, as occasionally I listen to all of the above.
On a side note, I admit I do tag my music files with one or more genre. On the other hand, I hate the strict categorization. Usually the music that doesn't obey the genre definitions but is on the (genre) edges, is the most interesting to me.
  • Last Edit: 23 July, 2012, 01:26:46 PM by GeSomeone
  • MahFlac
Mostly metal in all its various forms.
  • Exposure
Ethnic: Carnatic, Hindustani / Rajahstani, Qawwali / other Kashmir variants, Pakistanian variants (Sindh, and others), Afghan, Persian, Arabic variants, Berber, Gnawa, Turkish, Greek, Caucausian, Armenian, Ethno-Fusion from these traditions especially.
Electronic & Experimental: Goa Trance / Psytrance scene, including all fusions with ambient, breakbeat, DnB, 2-Step etc, and experimentation inside the scene (Australian scene, and Matsuri Productions label for example.) Oldskool Techno, Dub Techno, Acid Genres, Drill'n'Bass, Jungle / Darkstep, and experimentation in these fields as well. Some IDM, and Experimental Ambient and Soundscapes / Field Recordings as well (some of the releases, not the whole Genres). Some fusions of psychedelic Rock and Experimental Electronic, or Psy-Rock and Synthpop, or some Krautrock (Brainticket, Acid Mothers Temple and nick nicely are good examples.) A very little Post Industrial, Ritual-Industrial and other related to this scene. Any other thing that keeps it sofisticated, and push the boundaries of its host genre.
Israeli genres, or Israeli variants of the above, fusion or not, and some jewish religious / jewish kabbalistic as well. (Not foreign. But things local in Hebrew).
  • Jplus
I checked the boxes "Rock (Rock, Metal, Punk etc)", "Classic", "Jazz", "Electronic" and "genres which are not listed here". At first I would also check most of the other boxes (exceptions are "Pop", "Hip-Hop, Rap" and "Gospel") but then I saw the request to only check boxes for styles that you regularly listen to.
Some things that I'm missing:
  • Baroque, Romantic and Modern. Usually these periods are swept under "Classical" but I'd like to mention them explicitly because I actually tend to avoid the strict Classical period (1730~1820 according to Wikipedia) with composers such as Mozart and Haydn. Then still I would say these periods make for very broad categories, since nearly all other available checkboxes in the poll are of the same period (1960+ or "Contemporary" if you want).
  • Dance Electro (with styles like House and Trance) OR Art Electro (with styles like IDM and Ambient Electronic). The poll doesn't distinguish between the two but I can't imagine that "Electronic" refers to both since they differ considerably.
There are other categories which I think are missing, such as "Soundtrack", "Old" (meaning pre-1600s) and "Atonal", but I won't start a list here because I don't listen to those very often myself.
To be honest I think the categories are chosen rather erratically, both from the musical content perspective and from the expected bitrate perspective. Some are highly specific, such as "Reggae", "Soul" and "Gospel", while others are sweeping broad, such as "Rock (Rock, Metal, Punk etc)", "Jazz", "Electronic" (whether that means arty or dancy Electronic) and "Latin". I don't mind having very specific categories, nor do I object against very broad ones, but having both at the same time makes things fuzzy (for example consider Rock music that at the same can also be Blues, Country or Reggae). Still other categories are basically meaningless: "Ethnic/World" (the only binding factor is that it isn't Western or Latin, which doesn't tell you anything about content or bitrate), "Experimental" (I wonder whether there's any common denominator in this category at all) and as far as I'm concerned also "Classic" (the only common factor being that it's either orchestral or composed between 1600 and 1940).
So I hope the poll will turn out to be truly useful, but I'm afraid it won't. Your goals seems a bit overly ambitious for a forum poll; if you pick specific categories there will be too many to list in the poll, while if you make the categories too broad it will be impossible to say anything accurate about the associated bitrate.
  • Porcus
  • Jplus
Ha! Good heavens, no thank you... I think music genres are doomed to be a mess.
  • db1989
  • Global Moderator
If anyone wants it, I have split the, er, animated debate about compression and its relationship to genre away to its own thread in General Audio.
Rock, classical, kiiind of electronic music, i guess. Indie is often considered a genre, right?
Basically, i find trying to sort my music by genre to be a waste of time, since very few songs can actually be classified into a single genre.
I instead tag my music with very literal tags. Studio, Live, Orchestral, Ambient and such. I very rarely want a mix of these categories in a single playlist.
  • Last Edit: 12 February, 2013, 04:21:30 PM by andrew_berge
  • MusicExp
I listen to that dance electronic stuff
Pretty much everything this side of early music. In general, to twee, too beardy, too lentils.
Oh, and Vivaldi brings back bad memories of correcting and organising the publisher's database of every single damned one of his several hundred Concerti. While the music's good (mostly), there are memories of double vision and swollen hands from all the typing. The choral repertoire was a piece of piss by comparison.
  • Last Edit: 13 January, 2015, 03:51:25 PM by JabbaThePrawn
  • darkflame23
Mostly electronic ambient stuff here (Ishq being my fave, and my friend) but I love and listen regularly to many different genres and periods of music. Not a huge fan of jazz, classical or hip-hop although there is some I like a lot.
Share your thoughts
I vote for Rock, Classical and other unspecified music genres. Besides this I mostly listen to video game music, soundtracks and other instrumental stuff.
I could have gone on a lot more but "an occasional listening ... does not count". Suffice it to say I like almost any kind of music, some more than others though.
See 'About Me' page for my computer specs.
noise music, dark ambient, doom metal(drone, funeral and black), black metal with a very strong noise influence, power metal, symphonic metal, symphonic power metal and HNW.  also darker and heavier forms of Gothic metal.
