Easy-to-use audio CD image creator + burner
Reply #38 – 2012-07-24 16:49:26
Dynamic ... Thanks, but Write Audio CD option is missing on the latest version here (Windows XP): Any ideas? Sorry I've not been on the forums for a few days. NickC has reminded me that foo_burninate is required, so I thought I'd explicitly link his reply to your question to me. I had misremembered it as being a default component rather than an optional one. If you don't want to make your user install foobar2000 and foo_burninate, though, using the Right-click\Convert\... to create FLAC image + CUE at your end and using burrrn as greynol suggests to write the CD at the other end is probably a fine option too, though not one I'm familiar with as I don't have a remote user with such needs. If you want to put the workload at your end, here's my approach: I don't think fb2k will generate a CUE sheet from your m3u file, so personally, I know it'll work going through CUETools to create a CUE from a bunch of inidividual files. I'll also assume that your track number tags are not necessarily defining the order you want on the finished CD, so you need to make new track numbers, but don't want to overwrite the tagging of your existing WMAL files. This is how I'd do it: Start foobar2000 Load Playlist Right click on "playlist name" tab, click on "playlist name" contents, Convert, ... In the new dialogue window use: Output Format: FLAC (level 5 default will be fine), then hit Back Destination: Choose whatever empty folder you like, or set "Ask me later", then choose "Convert each track to an individual file", and set Name format: to %list_index% - %title% - %artist% hit Back If you need to, check the Processing dialogue or Other dialogue, hit Back Finally hit "Convert" to run the conversion. Now load all the newly converted FLAC files into a new playlist (or File/Add Folder...) and check the track order is correct. Right click on "New playlist" tab, click on "New playlist" contents, Tagging \ Manage Scripts... In the Masstagger window clear any existing Actions to perform, then Add \ Auto Track Number... and hit Run to renumber the track_number tags for the new disc you're compiling in the correct order they're displayed in fb2k's New playlist. You'll then have a load of flacs numbered in the playlist order, but otherwise tagged as your WMAL files were, while your WMAL files will remain unaltered. Run CUETools Select 'convert' from the pull down menu (top left) Drag the folder containing your FLACs to CUETools or Select All and Drag the music from foobar2000 onto CUETools. Set Template to something like: %music%\MyCDFLAC Action: Encode Mode: Embedded You can deselect the three metadata icons (MusicBrainz, freedb, AccurateRip) Audio Output: Lossless, flac, libFLAC is fine, so is compression strength 5 or 6. Finally, hit Go to create your Image.flac and Image.cue or Image.flac with embedded CUE. When done, you can delete the folder of separate FLACs. The CUEsheet (embedded or separate) will contain track number, TITLE and PERFORMER plus equivalent Disc information, presumably the sort of thing that would be nice to get written as CD-TEXT. if supported. Burrrn supports CD-TEXT (Settings, Writer) and seems to work from an embedded CUE in a FLAC image. Like most of the programs out there it just doesn't support WMALossless natively. Simply use Add to load the image FLAC and hit the Burrrn button.
