VBR V0 Bitrates close to 300 kbps
Reply #8 – 2012-07-05 21:47:05
I've posted the results of encoding a variety of music at different -V quality levels in a couple of other threads. Most end up in the 220 to 260 kbps average bitrate range, but I did see several over 290 kbps. Overall, LAME 3.99 increased the average bitrate of -V0 encoding compared to 3.98 to the point where you almost have to wonder if something is broken.http://www.hydrogenaudio.org/forums/index....st&p=796662 Here's a track that jumped from 253 kbps in LAME 3.98.4 to 299 kbps in LAME 3.99.5:M:\_Test-MP3>metamp3 --info "Ottmar Liebert - August Moon-V0-rw-3.98.4.mp3" metamp3 v0.91 - Copyright © 2006 by Tycho File: Ottmar Liebert - August Moon-V0-rw-3.98.4.mp3 Type : mpeg 1 layer III Mode : joint stereo Frequency : 44100 Hz Frames : 9671 Length : 00:04:12 Max. Reservoir : 208 Av. Reservoir : 66 Emphasis : none Scalefac : 1.2% Bad Last Frame : no Encoder : Lame 3.98 Bitrate (average) : 253 ----------------------------------------------------------- 64 0.0% 80 0.0% 96 0.0% 112 0.1% 128 0.4% 160 | 1.4% 192 |||||||||||||||| 15.3% 224 |||||||||||||||||||||||||||||||||||||||| 36.9% 256 |||||||||||||| 13.2% 320 ||||||||||||||||||||||||||||||||||| 32.6% ----------------------------------------------------------- Lame Header: Quality : 100 Version String : Lame 3.98 Tag Revision : 0 VBR Method : vbr-mtrh Lowpass Filter : 19500 Psycho-acoustic Model : nspsytune Safe Joint Stereo : yes nogap (continued) : no nogap (continuation) : no ATH Type : 4 ABR Bitrate : 32 Noise Shaping : 1 Stereo Mode : Joint Stereo Unwise Settings Used : no Input Frequency : 44.1kHz ID3 Tags: M:\_Test-MP3>metamp3 --info "Ottmar Liebert - August Moon-V0-rw-3.99.5.mp3" metamp3 v0.91 - Copyright © 2006 by Tycho File: Ottmar Liebert - August Moon-V0-rw-3.99.5.mp3 Type : mpeg 1 layer III Mode : joint stereo Frequency : 44100 Hz Frames : 9671 Length : 00:04:12 Max. Reservoir : 511 Av. Reservoir : 286 Emphasis : none Scalefac : 3.1% Bad Last Frame : no Encoder : Lame 3.99 Bitrate (average) : 299 ----------------------------------------------------------- 128 0.0% 160 0.0% 192 0.4% 224 || 4.4% 256 ||||||||||||| 24.4% 320 |||||||||||||||||||||||||||||||||||||||| 70.7% ----------------------------------------------------------- Lame Header: Quality : 100 Version String : Lame 3.99 Tag Revision : 0 VBR Method : vbr-mtrh Lowpass Filter : 22100 Psycho-acoustic Model : nspsytune Safe Joint Stereo : yes nogap (continued) : no nogap (continuation) : no ATH Type : 5 ABR Bitrate : 32 Noise Shaping : 1 Stereo Mode : Joint Stereo Unwise Settings Used : no Input Frequency : 44.1kHz ID3 Tags:
